Results 11 to 20 of 29
Thread: Make XP think it's running on batteries?
  1. #11
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by justchat_1 View Post
    Exactly!!
    I looked into this awhile ago and I think the problem I had was that windows only can use one ACPI HAL at a time....so you would need to create a replacement for the one currently used with your BIOS.
    I don't believe that's quite the way to do it, you want to write a new driver using the ddk, then you register it as a battery driver using CreateService. This driver then tells the OS "you have a battery installed" and the os believes it. No ACPI, no bios settings required.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Would it not be much easier to just plug in hardware to monitor the voltage level and run in the system tray and relay back and forth through the native windows API calls to whatever ACPI layer is running? So the program looks like the battery monitor (which wont be there in a desktop install anyways, so a duplicate isnt an issue), but is a custom program emulating it.
    Seems trivial. Hardest part would be characterizing your SLA over my SLA over ayone else's. A lithium battery is a bit more predictive in charge over a range then the cars. But it could be done.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    I thought acpi would give power info that would prevent windows from acknowledging the battery driver. I dug into it and your right, power states are reported but nothing that would indicate battery vs. ac power
  4. #14
    Newbie rickhigginshtbr's Avatar
    May 2009
    Hatboro, PA
    ....why don't you just get a voltage gauge?
  5. #15
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by rickhigginshtbr View Post
    Cause it would look very out of place in cleaner installs
  6. #16
    May 2009
    Hatboro, PA
    depending on the car, yes, but not in most cases. Plus, it could be put in a hidden area as well.
  7. #17
    Jun 2004
    Westminster, MD
    C'mon man... this is mp3car. The entire purpose of this website is to over-engineer a simple problem to provide an outrageously complicated but nonetheless elegant solution
  8. #18
    Dec 2008
    Quote Originally Posted by malcom2073 View Post
    far from it. i wouldnt have a carpc if it didnt make driving easier. reliability and convenience are key, and if i wanted a battery meter i would replace my analog one in my dash with a digital...
    i mean to put a meter inside windows just to do it is fine, however it will make zero difference to how you use your pc, and the for the trouble it will be i just wonder where the motivation comes from.
  9. #19
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Well it depends on how you use your PC... you could have a system that remains active with the car off until a certain battery level (so you can listen to music while at the gas station) and then automatically shutdown. You could also use the PC to give you ETA, so you know its safe to play music for the next X minutes and will still be able to start your car (unless you think watching the gauge and trying to figure out rate of discharge is more convenient).
    Is it easy to do? Depends if you want it at the OS level or the FE level...Worth it? Depends on your use...but zero difference? idts
  10. #20
    Dec 2008
    all that can be done with a simple shutdown controller, and it will be 100% automatic.. and 99.9% failsafe. putting a battery meter inside windows and trying to do all these things you want based off that just doesnt make sense when there are cheap hardware solutions that plug n play without hassles.
    i know op said 'just because', and thats fine. i just think there are so much better things you can do with that time itll take to pull off, so much cooler things....
  1. nGhost 2.0.2 on Ubuntu 9.0.4 - 'make' issue
    By ThePistonDoctor in forum LinuxICE
    Last Post: 07-23-2010, 08:30 PM
  2. Make Calls with BlackBerry through Win XP?
    By shooptek in forum Wireless Communications
    Last Post: 06-22-2009, 08:34 PM
  3. How To: Make Windows XP More Touchscreen Friendly
    By Maheriano in forum Operating System Optimization
    Last Post: 05-06-2009, 12:49 AM
  4. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 08:39 PM
  5. article on how to make XP boot up faster
    By blaster in forum Software & Software Development
    Last Post: 03-02-2005, 08:26 PM
