Results 1 to 4 of 4
Thread: Power PC from Cigarette adapter
    Nov 2009
    Canada
    Hey,
    I found a convenient power supply in my trunk. Is there any issues with using this to connect to my P2140, then to my PC? Rather than wire from my battery to my trunk.
    It has 12V output but would the amperage be a problem?
    Jan 2008
    it could be.
    using some of the car circuits to power a pc could lead to problems later if you start to draw more than what the wire can take.
    using a power wire that you ran yourself, or had someone else run for you, you can know exactly the current draw and can better plan and know what the limits of the wire are.
    Nov 2009
    Canada
    Fair enough,
    That would have been too easy ! you have the same concern as most on the forum, so I'll do it the proper way and utilize that power supply for another device. Like my rear camera.
    May 2006
    Calgary, Alberta
    *paging 2K1Toaster*
    *paging 2K1Toaster*
    *Your Microsoft Paint skills are needed in forum 10-G*
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. Question about Cigarette Lighter for power.
    By ninvertigo in forum General Hardware Discussion
    Last Post: 09-18-2007, 08:51 PM
