Results 1 to 3 of 3
Thread: Power Supply Issue
    Nov 2009
    Power Supply Issue
    Just a question, I have the m2-atx power supply and using jumper 2 setting. My question is should it shut down my computer after I turn the key off or should I have it setup to hibernate or sleep mode? Also, it the shutdown feature does not work all the time. Sometimes when I turn the car off the computer shuts down other times it just keeps running. Anything I can do to resolve that or is the power supply bad?
    Nov 2009
    Still need help
    update - ok the issue is when I turn the key off it send the command like it should to shut down the computer. Well, Riderunner is still running. So, it send a command to close out riderunner. Well, the key box shows up saying ending task. Well, it is not ending the task. It comes up end now or cancel. How can I set the computer up to automatically close out all open applications?
    Should the computer be going to in sleep mode, shut down, or hibernate mode when the m2 send the shut down signal?
    Jan 2008
    the shutdown/hibernate/sleep mode is setup in the power configuration menu of the os. the power supply will only simulate a power button press.
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Power a DC-DC PSU on a workbench
    By ssteger in forum VaultWiki
    Last Post: 10-14-2009, 06:07 PM
  3. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  4. Power Supply
    By MrGee in forum Newbie
    Last Post: 06-21-2006, 05:44 PM
  5. power inverter power supply shutdown problem
    By launter in forum Power Supplies
    Last Post: 09-21-2005, 12:12 PM
