Results 1 to 10 of 14
Thread: Mi carPC project...
    Nov 2009
    Peru
    Mi carPC project...
    I have a carPC project, but I want to listen if somebody was try before this config...
    AMD Athlon II 245
    2GB DDRII ram (1stick)
    Mainboard Foxconn Nvidia NF 6150
    DVD RW
    HDD Seagate 3.5" 250GB or 500GB
    Soundblaster Audigy
    TV and FM tuner card
    4 USB accesories
    I'm not sure about the PSU, because the processor is not avaiable in web PSU calculator.
    I read about M4-ATX 250W PSU, what do you think about this PSU?
    AMD sempron 140 (underclocked to 1.8Ghz) - foxconn 740G motherboard - 2GB DDRII - 320GB HDD (Laptop) - Power inverter - Lilliput 8 inch LED LCD... project under test...
    ride: Ford Taurus 1988 SW
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by masaki View Post
    AMD Athlon II 245
    DVD RW
    Soundblaster Audigy
    4 USB accesories
    Why are you going with such a high end setup?
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    a 250W psu might not do it for you with such a high end system, you may need to go with something a bit more powerful. I'm curious as to what kev asked, there's really no reason to go with such a high power system.
    RevFE
    My Shop
    Nov 2009
    Peru
    about config...
    my old config was an intel Atom mobo, and I have some problem to play some videos, so I want a more powerfull config, I found the AMD 245 processor very cheap, thats why I choose this config. my other option is a ion mobo, but here in my country is not avaiable...
    (I set the processor speed to 1.6Ghz manually)
    PS:
    I forget to say, Im from Peru... (sorry for my english)
    Dec 2009
    Bozeman, MT
    2gb of ram is a lot for just watching videos.
    Also the power supply may not be powerful enough to power all of that, I suggest using this power calculator to see what the minimum power your psu should put out.
    Nov 2009
    Peru
    result from calculator...
    1 physical CPU
    Athlon II X2 245 (underclocked to 1.8Ghz) (40W)
    1 stick DDRII SDram (2GB)
    1 video card Nvidia 6200 (I don't have this, but since the chipset have intgratted 6150 graphics...)
    1 regular SATA HDD
    1 DVD RW drive
    1 PCI soundblaster Audigy 2ZS
    1 generic TV/FM tuner
    5 USB devices
    1 fan 80mm
    System Load 90% (recomended)
    Minimun PSU wattage: 190W (without DVD 164W)
    I will change the regular SATA with a laptop 2.5" HDD and add a usb DVD external powered....
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    if you have doubts of not having enough power then get an OPUS 360watt PSU
    Dec 2009
    Bozeman, MT
    1 physical CPU
    1 regular SATA HDD
    1 DVD RW drive
    5 USB devices
    1 fan 80mm
    Oh. In that case it looks good to me if you are going to underclock.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    You can't look only at total power you need to look at current draw for each rail...
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    what kind of video are you trying to play? dvd, or any standard def video should play fine. It's when you get into high def that you would need to worry about the atom not being able to cut it (ION excepted of course).
    At any rate, get a big opus and hope that your alternator doesn't die in a few months.
  1. Skoda Felicia Fun,My first CarPC Project
    By zeecue in forum Worklogs
    Last Post: 10-12-2008, 05:26 AM
  2. BMW E38 carPC project
    By Evlo in forum General Hardware Discussion
    Last Post: 09-25-2008, 12:56 PM
  3. Replies: 3
    Last Post: 06-18-2008, 12:16 PM
  4. Turbulence CarPC project - by radu on hyundai Tiburon '00
    By radu81 in forum Show off your project
    Last Post: 05-18-2008, 10:52 AM
  5. Replies: 2
    Last Post: 09-29-2005, 07:29 AM
