Results 1 to 10 of 19
Thread: battery isolator vs relay
    Oct 2001
    Ontario, Canada
    I've got a question about using a relay (cheap) vs a battery isolator/diodes (expensive!)
    Before I go any further, I know about the "reason" why you should never use a relay, namely once the relay closes the drained battery will draw 47 billion amps from the charged battery, damaging both batteries and melting wires and causing large fires in the process.
    But instead, what if the relay was attached to close only about 5-10s after the engine was started?
    Then the power will be provided by the alternator instead of draining the primary battery, this should work, no?
    Alternatively, can I just build a battery isolator using a couple of diodes? Hell, even those diodes are much more expensive than a relay. You'd need what, probably 100-120A diodes, or 2x60? At like $10 each you'll need what, 4 of them? Still not a very cheap venture.
    [Edit: I'm on crack, you can get MBR6045's for like $3 each... $12 for diodes + wires + heatsink isn't that expensive. And yeah you can buy them for $40 or so, the place I was looking at was grossly overpriced.]
    I tried searching for topics like this here and didn't find any.
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
    Aug 1999
    Washington D.C.
    Is a battery isolator really all that expensive? I seem to remember seeing a low amp one GI Jo's for about $30 and a high amp one for about $50.
    Sep 2002
    Manitoba, Canada
    Here is a good site that illustrates three different ways of connecting two batteries to one alternator.
    Direct Page Link
    It shows a) Diode Type Isolators - same as the ones you buy b) Solenoid Type Isolators - manually switched isolator and c) Dual batteries without an isolator.
    Piles of good info at this site, here is their Main Page
    Chkdsk
    Shuttle ST62K, 80Gb, MediaEngine, Irman, Wireless NIC, Win2K, Blah Blah Blah...
    Oct 2001
    Ontario, Canada
    The isolators that I saw were like $100 (CDN) sorry, I was looking at http://www.sounddomain.com/shop/list...ors/Regulators
    As I keep searching though, the only decent ones that I see are > $50USD, which in my books constitutes "expensive" for what I want, especially since I could build one for like $8USD (using 2 or 3 45V 60A diodes in parallel for each direction)
    And now that I think about it, maybe I'll just build one.
    I'm trying to figure out other neat ways of doing this... I was thinking maybe using solar cells to augment the power supply. Basically you need about 250mA at 5V (so 1.25W, or 1.8W with switching regulator, or 3W with a linear). So with a 5W solar cell, you should be able to power the computer in STR during the day and generate enough power to charge the battery to recover the loss drained during the night. You can get a 5-watt solar charger for $50USD over here at Canadian Tire (probably cheaper elsewhere). Could be interesting.
    Apr 2003
    Lets see where this goes...I am very interested...did you ever think about trying it in a friends junker first...lol
    I am thinking about just saying F-it and running dual alternators...very expensive
    JMM
    Oct 2001
    Ontario, Canada
    I don't see how dual alternators would really help anything, unless the problem is you're drawing too much power for the poor alternator to handle.
    The issue here is a dual battery system and how to isolate them.
    I think either method would work, but using diodes (since you can actually make one yourself for ~$20 all-said-and-done) seems like the best solution.
    Apr 2003
    well, i have so much crap in my car now, i am worried about the pull on the alternator...so yes, the diode method seems like it may be good in my situation also....hmm, i would like to see how this goes.....got an update?
    JMM
    Oct 2001
    Ontario, Canada
    no, in the last 15 minutes nothing has changed.
    Ask me after tuesday (last exam). Then I'll be playing with all my stuff
    Apr 2003
    LOL, no Telek...the 'got an update' part was intended for the person who started this forum...I am not an idiot...lol, that was funny...
    jmm, did you get the post about the Krocera vga screens on ebay...I posted to you in the one we have going, "Mailbox is full, Question for Telek"....
    JMM
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    well i don't know just how young you guys are , but i've been buying stuff from jc whitney for a real long time. i got my battery isolator from them. bought it around 1980 for a van-never used it. put it in my car in '86. its never let me down yet. sometimes you can get pretty good stuff there for a good price--just dont buy their tools!
