Results 1 to 10 of 15
Thread: Aux. Battery oops :S
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    So I did bad and didn't mount my aux battery in the trunk. It was situated between my sub box and the sidewall. There wasn't much room to move, but I guess there was just enough to cause badness.
    On the way home from lunch a few days ago my subs went out. I found out today that my battery had tipped over and melted itself to the chassis of the car. It was only the plastic from the connecting forks that melted but still. luckily the 30A fuse blew that connects the aux from my main battery.
    I secured my aux so it won't happen again and replaced the fuse. I'm noticing that there is a bulge now in the side of the battery. Should I be worried about this? The last thing I want is a battery to explode.
    Any thoughts?
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Raw Wave
    Nov 2009
    Yes - it could be a worry....
    It's physically damaged so there can be internal shorts and bad cells.
    Even if not initially hazardous (shorts & thermal runaway etc), the cells are probably mismatched hence uneven charging then collapsed cells, then gassing etc....
    You were lucky the battery didn't explode of start a fire etc - those AGMs typically have at least double the short-circuit current or wet cells.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I wouldn't trust it. Get a new one and chalk it up to experience.
    Want to:
    Low Bitrate majasticmoose's Avatar
    Dec 2009
    Yes there is an excellent chance it will explode. It is gassing which is caused it to bulge which flammable hydrogen gas has built up and could explode. Read here http://en.wikipedia.org/wiki/Car_bat...ding_batteries
    Replace the battery, btw what is the difference between a normal and your car audio battery?
    Andrew
    Raw Wave
    Nov 2009
    Can't be much if the fuse is only 30A.... (ie, under 500W of audio)....
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Yeah, i'm not pulling over 500W. I took the battery out and I'm getting a new one. I'm planning on building a proper mount for all this stuff so I can avoid this moving forward.
    My "normal" is a optima yellow top. The second battery is about half the size and I'm guessing, won't last as long as the bigger battery when drawing from it. I got it because it was smaller and thus easier to place in the wrong spot :P.
    Jun 2007
    St. Louis
    What did you use to secure the new battery? I just put a Marine Deep Cycle in my trunk and am using a cheap $8 vented battery box from Wal-Mart secured down with a metal strap. The battery is about 40lbs or more and was just wondering if that's enough or I might need more.
    Raw Wave
    Nov 2009
    If you corner hard or stop hard, or hit another car, will it break loose?
    If it breaks loose, will it short out and start a fire, or will you have a permanently embedded battery for later pacemakers?
    They are the issues....
    (I assume everyone has fuses or circuit breakers at each end of the interconnecting battery cable?!!)
    And I for one hope they are not paralleled when not charging....
    That reminds me - OptimaJim still hasn't substantiated.....
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by OldSpark View Post
    I don't know if those questions were for me, but I do have fuses all over the place. I did have them linked when not charging. I am not running anything when it's off yet, when I do, i'll add in my 80A relay.
    Raw Wave
    Nov 2009
    My original about cornering and being fixed was in response to nst6563's $8 vented box. (Over here I have seen tests that show a box of tissues from a rear parcel tray is enough to kill in an accident, though other permanent damage is more likely. But that's a box of tissues which IMO is not as heavy as a battery...)
    The fusing & paralleling is a general comment....
    Many forget to have protection (fuses or breakers) at BOTH the 2nd battery and the 1st/main battery (on circuit/cable line that joins them).
    Paralleling of batteries should not be done except when charging else when being used.
    Paralleling of idle batteries of different types, ages and temperatures should NOT be done.
    Now even though OptimaJim (eCare Manager for Optima) stated that Optima's could be paralleled, he hasn't come back with any evidence to support it... but thanks to this thread reminding me, I emailed Optina lastnight....
    Paralleling idle batteries is just a means of prematurely destroying good batteries. (I've likened it to the old practice of tyre rotation except that one bad wearing tyre won't effect thye other good ones (until AFTER the rotation).)
    Paralleling new & matched batteries is usually okay for a while, but when one battery starts its decline, they all go. And the problem is that could be hazardous - especially for AGM batteries (thermal runaway... some people claim LEDs are bad - but they aren't power sources....).
    The frustrating thing about not-paralleling except when charging is so easy to solve....
    Simply use your alternator's charge-lamp circuit to control a relay that connects the 2nd battery.
    When not charging, the 2nd battery stands alone and powers whatever it needs to.
    If the 2nd battery flattens, who cares? - the primary battery is still there as normal.
    If you want more 2nd battery reserve (for audio at the campsite etc), then you add more secondary batteries... How they are paralleled may not be as significant if they are all matched, cross connected, and in the boot etc (rather than one hot battery in the engine bay....)
    If you are NOT running anything of the second battery, leave them disconnected - especially since they are AGMs.
  1. 2 battery's
    By zbone1 in forum Newbie
    Last Post: 03-29-2009, 01:52 PM
  2. What kind of cap/amp?
    By asong31 in forum Car Audio
    Last Post: 12-26-2006, 02:30 PM
  3. 2nd Battery, Wiring Idea.
    By jmcclure22 in forum Newbie
    Last Post: 11-19-2006, 11:51 PM
  4. opus with small aux battery?
    By kuo in forum Power Supplies
    Last Post: 01-12-2005, 10:42 PM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
