Results 1 to 4 of 4
Thread: 12v to 5V Power supply build?
    Feb 2008
    I have a laptop-based install. I have the DC-DC USB programmable power supply from mini-box.com powering/controlling everything. This device only has a 12V Auxiliary out and 19v out to the computer. I have a 7 port USB power supply that accepts a 5V external power supply, I definitely do need it because it won't charge my phone and operate a thumbdrive at the same time saddly.
    What's the best way to build/buy a 5v Power supply with enough amperage to power many devices. Through this hub I plant to run the GPS, OBD reader, female jack in the glovebox, two female jacks on the dash for misc stuff.
    Thanks for your support and help.
    -steve
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    A 7-port USB hub running full output on every port usually consumes about 3.5-3.7 amp (obviously at 5 volts). Now that is IF EVERY ports is being used at maximum capacity.
    You could buy a 5-volt POL PSU, most of which put out 15watts (3 amps) which for most cases is plenty of power for a 7-port hub.
    http://store.mp3car.com/Carnetix_CNX..._p/pwr-016.htm
    or
    http://store.mp3car.com/Automotive_P..._p/pwr-022.htm
    Jan 2008
    Dartmouth, MA
    Watch out with the carnetix. It needs a heatsink. At 2 amps draw, it's at 110 degrees fahrenheit. At 3, it pushes 140. These are linear regulators so the heat is to be expected with such a voltage drop.
    I just ordered the 50 watt switching regulator from here to replace it: http://jameco.com
    But they also sell 25 watt switching regulators for cheaper than mp3car's linear regulators.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Raw Wave
    Nov 2009
    There are times I like simple linear converters - like the 7805 or LM317K etc - with a booster 2N3055 etc. Small, no noise, cheap, etc.
    But there's its 40W of heat at 14.5V supply and 4A output....
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  3. Review: M4-ATX 250 Watt Intelligent Power Supply
    By Bugbyte in forum The Review Palace
    Last Post: 12-21-2009, 09:52 AM
  4. What Power Supply for Laptop Install?
    By D3LTR33 in forum Newbie
    Last Post: 08-04-2008, 07:41 AM
  5. Getting 5v AND 12v from POL DC-DC Smart Power Supply
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 06-19-2007, 12:09 PM
