Results 1 to 6 of 6
Thread: New(?) 70Watt snap-on PS for EPIA-M boards
    cj
    cj is offline
    Aug 2001
    In case you haven't already seen this, Mini-box.com is soon to be shipping a 70W PS for the EPIA-M. The concept is similar to their 60W for the normal EPIA board.
    http://www.mini-box.com/pw-70.htm
    Also, I read something on their site Friday that they would also be shipping a shutdown controller or a version of the PS with that capability onboard. Unfortunately, I can't find it anymore so they may not be as close to shipping that product as they thought they were. Either that or I'm going insane.
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    but I believe these you use an AC plug to use. So you cant hard wire it to your car.
    Mine needs to be updated.
    Jul 2002
    Seattle WA
    I know the 60W version from these guys has been hard wired to a car,
    http://www.thisstrife.com/carproject/index.asp
    and their webpage says it is a DC-DC solution. You can buy the AC adapter to use in the home.
    New site at
    http://customcarpc.dreamhost.com
    http://home.attbi.com/~rbarr110
    2002 Toyota Tacoma Doublecab
    Apr 2003
    Western MA
    So who wants one? Once they're released we can get 20% off if we order 5+ units.
    I want one
    ps - This is my first post here.. I've been reading for a while though. Hi everybody!
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I thought those power supplies used 12vdc regulated input.
    So all you need is to supply a regulated 5-8A 12vdc input.
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    yes in theory all those power supplies need are 5-8A's or current at 12 volts.. BUt .. car voltage goes up and down all the time.
    I know for a fact the car holds at about 12.2 - 12.4 volts all the time, and that drops when ignition is on, off.
    I mean you can use these power supplies but you will have to find a way to handle the ignition on/off and the voltage fluctuations.
    I believe some mentioned to me about something called a "tank circuit" I thikn thats to help with the ignition on/off problem.
