Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: hybrid dual sproggys....
  1. #11
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    I know its my power supply at fault, thats why im TRYING to fix it. Thanks for you help:P But one thing that sticks in my mind is this. Why does this sproggy supply i have biult, work with any other atx motherboard, but not an EPIA????? Did you ever think of that Rob withey??
    Ford XR6T blueprint 4.0 L twin cam turbo.
    Xenarc 7" touchscreen M10000 Audigy 2 NX
    ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
    Griffin Powermate Panasonic DVD-CDW
    Pioneer 5x7 Four way, 2x12 pioneer subz
    600watt 6chan USA audio AMP
  2. #12
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Yep, simply because other boards are not so fussy on the ATX spec. Your Epia works with a standard ATX power supply, right?
    Did you ever think about that, stimps??
    Rob
  3. #13
    Nov 2001
    brisbane
    of course you friggin twit.
  4. #14
    Apr 2000
    Bedfordshire, UK
    Oooh, temper temper. I'll refrain from stooping to your level and instead offer you some free advice.
    You're a newbie here. You don't get things for free, especially from manufacturers. I have been in the mp3car business for 4 years now. I have setup that I planned, designed and built and got it right from the start and that has changed very little in that time. As for me being a twit, I suggest you look at who is still fumbling with power supplies and is expecting freebie support from a manufacturer on a product you didn't even buy from them.
    I wish you luck.
    Rob
  5. #15
    Nov 2001
    brisbane
    Originally posted by Rob Withey
    No disrespect intended, but it is your power supply that is at fault, not their motherboard. Why should they help debug your power supply for you?
    Rob
    mate, your the one who started this, so just **** right off. All i was looking for was some constructive help. Not destructive critisim. If you dont have anything to add, just shut the **** up.
  6. #16
    Apr 2000
    Bedfordshire, UK
    Have you tried bypassing the Sproggy power good and manually applying power good? I understand there may be issues with the slew rate or timing on the sproggies power good rail.
    Someone was also talking about using a PIC to give a better timed power good line. Here:
    Sproggy is ALIVE
    Someone got an epia to POST with a pulsed power good. Unfortunately the next pulse powered it off. However, it does suggest that it is power good related.
    Rob
  7. #17
    Nov 2001
    brisbane
    yes I have tried that. I have not yet made up a timed pulse circiut to accurately control the timing of the power good signal.
  8. #18
    Apr 2000
    Bedfordshire, UK
    This guy got a sproggy working with an epia:
    I'm out of ideas (Sproggy mk2.8/+ ???)
    Rob
  9. #19
    Apr 2000
    Bedfordshire, UK
  10. #20
    Nov 2002
    Berkshire, England
    You'd need a fast hand to get it within atx specs anyway but the bounce off the contacts would create havok.
    Has anyone tried my idea? I was a bit supprised everyone ignored it, concidering the validity of the point.
