Yellow goes to the accessory wire on the car. It tells the Opus to turn on when the car turns on and off when the car turns off.
If you want to test the setup, then reconnect the black and red to - and + and then supply 12v to the yellow wire. If you have connected everything inside the computer properly (including the ACPI jumper) it should power on.
LinkBack URL
About LinkBacks
I use a
