Results 1 to 7 of 7
Thread: I need help Calculating power consumption.
    Newbie atombomb's Avatar
    Apr 2003
    Poulsbo
    I would like to use my multimeter to check the total draw of my system while in different states. By states I mean ON, OFF, different power savings modes, Stand by, etc. I would then like to take the consumption rates and calculate pull on the battery per hour or how long the system will render the battery unusable to start the car.
    How do I measure the current draw?
    What are the needed calculations to measure the life of the battery.
    David
    http://www.carputer.info/
    mobile nerd
    Apr 2003
    The multimeter must be able to read current (not all do) and be rated high enough for your computer. You'll want to use thje amps setting on the multimeter. Amps are equal to watts/volts, so if you've got a 100 watt power supply and the battery is at 12 volts, your multmeter must be able to handle up to 100/12=~8.3 amps. Chances are you aren't going to hit the max current draw, but if your multimeter is way off, then don't try it or you'll fry your meter. (it'll just blow a fuse if it's feeling generous)
    To measure current draw, put the multimeter probes in the correct holes on the multimeter for measuring amps, then put the multimeter in series with your curcuit. Something like this:
    +car battery --- multimeter --- +power supply
    -car battery ------------------ -power supply
    Batteries are rated in amp-hours for a specific current draw. A 20 Ah battery may deliver 1 amp for 20 hours. You'll actually get a bit more or less, depending on the battery, and the total available amp-hours can change, depending on the current draw. A 20 Ah battery that runs for 20 hours at 1 amp, may run for 45 hours at .5 amps or 6 hours at 2 amps.
    I don't know how much charge a battery needs to have to start the car.
    I'm a tinkerer and don't have any electronics background, so my apologies if I am mistaken on any technical points, but the general concepts should be correct.
    Apr 2003
    Poulsbo
    good star
    Thanks for the info. I am going to head out to the shop and check the multimeter.
    I want to make sure my total pull doesn't get out of control when I start adding more pieces to the puzzle. I also need to document some base line draw numbers for the system I have so I can make comparisons to other configurations that I may be testing in the future.
    David
    mobile nerd
    Jul 2002
    Seattle WA
    Question for UTAHRC
    SO if I understand what you posted correctly,
    Amps = Watt/Volts therefore
    Watt = Amps x Volts ?
    Becasue I am trying to figure out how much of a PSU my system really needs.
    For example my laptop dvd drive says on its label "5V DC 5A"
    So does that mean it uses 25 Watts? 25 watts seems high for a laptop device.
    (Maybe it was "5V DC 5mA" hmmm, better check that out)
    New site at
    http://customcarpc.dreamhost.com
    http://home.attbi.com/~rbarr110
    2002 Toyota Tacoma Doublecab
    Apr 2001
    Portland OR
    Re: Question for UTAHRC
    You can use 0.01 ohm 1% resistors and measure the voltage across them. You hook them in series with the load. It will give a better measurement than using the multimeter, but will require that you build a jig that puts the resistors inline with the load.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Apr 2003
    Correct,
    Watts = Amps * Volts
    Amps = Watts / Volts
    Volts = Watts / Amps
    Your DVD drive is rated for 25 Watts, though is likely the maximum draw, which may only occur momentarily, such as when a disc is spinning up. When there's no disk in the drive, it may only be drawing a few amps.
    Jul 2002
    Seattle WA
    Well I looked at the dvd rom again, and my memory was a bit off.
    The label said "5V 1.5A" = 7.5 Watts
    Much better.
    Thanks For the help
    New site at
