Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 12V 4.16amps
  1. #11
    Aug 2002
    Ummm. It's an ISR. Integrated Switching Regulator.
    http://www-s.ti.com/sc/ds/pt6656.pdf
    Doesn't "switching regulator" mean it will step up or down as needed?
  2. #12
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Nope, read the spec sheet again. In particular, may I refer you to the specs on the Input Voltage Range where it says that the minimum is Vo+3. Ie, you need 3V of headroom on the regulator.
    Rob
  3. #13
    Aug 2002
  4. #14
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    Nope
    A switching regualtor can be just step down, or just step up, or both. The 6656 is a step down, a PT4051 for example is a atep up. Switching basically means just that switching. It has some sort of oscolator that pulses a switching transsitor to switch the input on and off fasy at the percentage needed to create the output. For step up they pulse the input through a coil to get a higher output. Look at the whole family chart http://focus.ti.com/docs/search/para...e&familyId=563 in the last colum at the description for step up/ step down/etc.
