i have an opus dcx6 360W DC-DC vehicle converter. I've put my carputer together and tested everything with a regular PC power supply before removing said power supply. I then installed the DC converter and hooked everything up accordingly. I have the carputer set up on a bench with my dc power supply that puts out 12.5V and capable of 24amps.
The Dcx6 jumper settings are as follows:
Startup voltage is set to lowest as possible (no jumper)
Im operating is IGNITION MODE (no jumper)
2 pin "P/S ON" wire from dcx6 to motherboard
All yellow input wires are connected to 12v
all black ground wires connected to ground
RED Acc. (ignition) wire is connected to 12v
when i turn the power on and wait 10 sec (for delay) the motherboard fans come on for 2 seconds then shut off. it goes back to standby/idle mode. I noticed the dcx6 is by default in ATX mode.
for the hell of it i put a jumper on the pins that switch it to AT mode. now when i power up the unit I get a solid LED indicator and the fans stay on the mobo "appearing" to work correctly. except i hear no power on beep from BIOS and I have no video display. what am i doing wrong? what is a mini-itx motherboard considered to be for power requirements, AT or ATX? I've got something wrong...
