Results 1 to 10 of 20
Thread: Small, cheap, 12V-12V regulator
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Possibly related to this post I just made
    What's the smallest/cheapest 12V-12V regulator out there? I don't want an ATX power supply, I just want something like the Carnetix P5V, but with twelve volts out instead of five.
    Can anyone advise?
    The Carnetix section of the mp3car store doesn't seem to contain anything appropriately small and cheap, nor the PSU section. I looked at mini-box website and all their really small PSUs appear to be ATX form factor - hardly convenient when what I really want is two wires, one that spits out electricities and one that takes them back in again.
    Thanks,
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Mar 2009
    Los Angeles
    Of course, I write that and then I go find this bad boy:
    picoUPS 120 12V DC micro UPS
    What do you think? It's not available on the mp3car store, but it looks like even if I don't put a battery on it, it'll do what I want. For bonus points, I could put a battery on it and actually enjoy a UPS for my pogoplug...
    Gary (-;
    Oct 2006
    http://store.mp3car.com/Intelligent_..._p/pwr-034.htm
    this is a nice option too depending on your need
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    How much current do you need? eBay has some switching regulators that do 1A for <$20.
    Mar 2009
    Los Angeles
    Punky: I actually have one of those at home, but for this particular project I'm shooting for something smaller.
    Nobb; nominally 8W, although startup will possibly be a bit more. [so... two thirds of an amp, but possibly more than 1A]
    Gary (-;
    Oct 2006
    you can do that using a single tiny regulator, there'll be a bit of heat thats all.
    Mar 2009
    Los Angeles
    How would that work?
    The truth, of course, is that now I'm thinking about putting in a UPS on purpose...
    Gary (-;
    Raw Wave
    Nov 2009
    I think Punky is forgetting the drop-out voltage as well as up conversion.
    FYI - a versatile kit for up to 50W, or 100W heatsinked (AUD$22.50 + P&P) - see Oatley Electronics Kit K168 - DC to DC Converter
    Oct 2006
    I remembered looking this up at one point. I think this chip can do it:
    http://www.national.com/ds/LM/LM138.pdf
    However, for the cost, oldspark's suggestion will most likely be cheaper and easier.
    Raw Wave
    Nov 2009
    The LM138 drops at least 1.5V across it, hence you need 13.5V in to get 12V out. (It's similar to the LM117/317, 780x & 790x 3-terminal regulators.)
    In this application, being a UPS I assumed a typical 12V supply to supply 12V, hence say 11V - 15V in assuming a battery, or 8-16V in using typical automotive design specs.
    If that regulation wasn't required, why not connect 12v to 12V?
    Pity though - for 8W, cheap $2-$3 fixed 12V 7812 or adjustable 317k regs would do (up to 1.5A output).
