Results 1 to 9 of 9
Thread: VoomPC Case with M2-ATX supply having j8 problems
    May 2005
    Exclamation VoomPC Case with M2-ATX supply having j8 problems
    It appears that my M2 is having issues.
    During bench testing with a 20a ham power supply, the M2 will power up properly.
    However, when I disconnect the ignition power, the M2 will simply drop power to the mobo after about 7 seconds.
    About 5 seconds after that, power comes back on to the mobo, then shuts off after 1 second, this cycle repeats until i physically kill power alltogether.
    I have tried different polarities running from j8 to the mobo power header with no difference. As a matter of fact, this happens whether j8 is connected or not.
    Please help!
    Elsewhere
    Is the M2 in dumb mode?
    How about the Wiki?
    Dec 2007
    Sydney Australia
    What is the output voltage of the 20A ham power supply ?
    I wonder if either it or the M2 is over-voltage tripping when there is a load change.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Quote Originally Posted by DarquePervert View Post
    I like DP's question here. Here's a link to the M2-ATX manual. On page 2 and 3 it talks about the different jumper settings for power functions with the M2. Try setting it to P1 then try connecting & powering up the M2 with the PSU.
    May 2005
    Unhappy
    Sorry, did not provide enough information. It was late and I was tired.
    The M2 is in P1 mode. Tried also in P4 with the same results. (slightly longer delay till it killed power i seem to remember)
    The power supply is putting out 13.75v steady
    The motherboard is a jetway jnc62k.
    Once i am up and running (after switching the power supply OFF, then back on after a few seconds) all is fine. It just freaks out after i simulate key off by disconnecting the ACC line.
    I can manually initiate a hibernate by shorting the power pins on the motherboard and that works fine.
    Hooking my meter up to the J8 leads, either it shorts them so fast i cant see it on the meter, or it does not short them at all.
    Jan 2009
    Iowa
    I guess I would test it in the car next to see if you have the same issues. If you don't it could just be something with the way the HAM PSU is providing power/the way the M2 senses it.
    May 2005
    Well darn. It appears that even testing with an actual car battery produces the same problem.
    Am I just SOL now? The unit is out of warranty I imagine. Though, now that I think of it, I don't know how long the warranty is actually.
    Any other advise would be greatly appreciated!
    Jan 2009
    Iowa
    How old is the M2 you purchased? You can always contact 'em and see if they'll do anything for ya.
    May 2005
    It is a couple years old. 8(
    I did contact them and pointed them at this thread as well.
    Will let everyone know how it turns out.
    Thanks for the time and help!
  1. M2 atx J8 busted?
    By Project_330CI in forum M2-ATX
    Last Post: 10-12-2012, 03:29 AM
  2. hooking up amp remote wire to m2 atx
    By mm87 in forum Car Audio
    Last Post: 07-16-2009, 02:11 PM
  3. Hardware Review: VoomPC-2 Case
    By TravisT in forum The Review Palace
    Last Post: 01-30-2009, 05:06 AM
  4. VoomPC Case + Carnetix P1900
    By Zerach in forum General Hardware Discussion
    Last Post: 07-21-2007, 04:08 PM
  5. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 02:19 PM
Tags for this Thread
