Results 1 to 6 of 6
Thread: Would this schematic work?
    Newbie dsoares's Avatar
    Aug 2002
    VITORIA-ES-BRAZIL
    Post your comments, please....
    Thanks,
    Diego Soares
    Mar 2002
    Emeryville
    I remember reading somewhere the following:
    I think it will not offer any current limiting/ protection. Also the heat dissipation by the transistor would be great.
    A similar idea was to use just a 7805 instead of a switcher. The current through it will be limited to around 1A and the rest would be supplied by the bypass transistor.
    You could add a crowbar for protection.
    Aug 2002
    VITORIA-ES-BRAZIL
    Well... you're right.
    MAX787 can supply 5A and I'll be using only 1A.
    OK!
    But, what do you say about this schematic:
    I know the heat dissipation in the transistor would be great too, but, in this way, we could have a more powerfull +12V PSU.
    I don't know what will happen when cranking because the collector voltage will be minor than the base voltage.
    Diego Soares
    Apr 2001
    Portland OR
    OK!
    This won't work at all.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Aug 2002
    VITORIA-ES-BRAZIL
    Why?
    Diego Soares
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Why?
    I'm not quite sure what you are trying to achieve, but you appear to have bolted a linear pass transistor onto the backend of a switcher. There is a reason that people don't use linear regulators for the 12v section of their power supply. That transistor requires 0.6v headroom. It introduces a series resistance (the Vbe sense resistor) into the only section of the power supply that is capable of supplying 12v when the input voltage drops.
    Rob
