Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Help with my tank circuit.
  1. #11
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    thanks man! You have been most helpful.
  2. #12
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Would there be a problem of overcharging the gel cell?
    I came across this site. It talks about adding a limiting resistor to safely charge the gel cell.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
  3. #13
    Apr 2001
    Portland OR
    You don't need the resistor or the extra diode. That is being anal and isn't really nessessary. plus the "float" voltage the car puts out is well within the range of the Gel cell.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  4. #14
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I don't know about this setup, but if you have two batteries hooked directly to each other and the alternator (like in my diesel truck) you need two batteries of the same capacity, or else one may get overcharged/fail/worse.
    Perhaps having your battery on its own circuit and isolated might be different.
  5. #15
    Apr 2001
    Portland OR
    How can you overcharge a wetcell battery that charges by having a constant voltage? I can see the argument about having too much inrush current if one is depleted (a smaller battery). If the two batteries are in parallel and they are of different capacities, one runs out faster, but the voltage at the terminals are the same for both, so all the current just comes out of the one with more capacity.
    NiCads are trickle charged with a constant current, IE if you hooked a 1.2 volt nicad to a current limited 25 volt source, and set the max current to 50 milliamps, it could charge forever and not get hurt. Where as if you put a wet cell battery in this situation it would kill it after a while because it would try to charge to 25 volts.
    So if I'm understanding it correctly, to charge it, you take a wetcell battery (like in a car) and you just hook it directly up to 13.8 volts, if the battery is low, it sucks a lot of current, it is the regulators job to not exceed initial current rating. So if you have two batteries, the regulator cuts out sooner, if they are different capacity, one will take more current, but they will both charge to the same voltage.
    Can someone help me understand why you need Isolation? And why this is even a problem?
    www.mpegbox.com
  6. #16
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Well I don't know about isolation, but the battery came in today and it solved my problem. Thanks Jeff!
  7. #17
    Apr 2001
    Portland OR
    If you don't let it get too discharged, Isolation shouldn't be a problem. If you run the thing for a long period of time with the car off, there is a chance you could exceed that initial current rating..
    -Jeff
    www.mpegbox.com
