Results 1 to 10 of 17
Thread: Help with my tank circuit.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    I built a tank circuit using this diagram:
    I actually used (2) 2200MFD 50V caps wired in paralell.
    I used an MBR3045 and went and hooked it up.
    The computer wouldn't boot so I broke out the multimeter and while it was getting over 12V coming in it was only registering 3.18V going out (and into the PSU). So I decided to hook up a 1/2W resistor to it and charge the caps.
    Well they get to about 10.5V and then go back down to 3 or so volts. And do so repeatedly. What's going on here? Help me!
    Dec 2002
    West Orange, NJ USA
    The diode is reversed? (Your diagram is right, BTW.)
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Well it was a short and I fixed it. After that my computer powered up beautifully and then for the test...
    I started the engine... and the computer rebooted . What now?
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    What do you mean? How could it be reversed? A and A go to the battery and K goes to the cap(s), right?
    Apr 2001
    Portland OR
    Nope, your diode it connected right. You could try a few things. Replace the CAP with a small gel cell 12 volt battery, or replace the CAP with a 1 farad cap. Or, replace the Diode with one with less forward voltage drop.
    Hey, where did you get that diagram?
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    -Jeff
    Here:
    Tank circuit
    but you probably already know that now.
    Also, I just remove the caps and replace them with a small 12V gel cell wired the same way?
    Also, you made mention of other diodes. I'm using a 250W Top Micro DC-DC Converter. Which diode would you reccomend?
    I'm trying to get away from using a big assed cap due to space where I need to mount it. Would a .5 Farad cap work?
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    On this page:
    http://www.batterystuff.com/battery/batteries.htm
    Would the ES 1.2-12 or the ES 1.9-12 be ideal for this?
    Or what about this one?
    http://cgi.ebay.com/ws/eBayISAPI.dll...&category=1200
    Apr 2001
    Portland OR
    On this page:
    Yes, just replace the Cap by the battery. I would go with the 4-12 but there is a chance the smaller ones would work..
    www.mpegbox.com
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    So I keep the diode? Is it really necessary with the 4-12 (which I just bought)?
    Apr 2001
    Portland OR
    Yes you keep the diode. It is still important. Car cranking could still bring down the voltage at your spare battery if you don't have the diode.
    www.mpegbox.com
