Results 1 to 8 of 8
Thread: Stuck with HP Slimline Power Supply
    Apr 2009
    I got all my stuff pretty much ready for my 350z...im debating if I should go with a small powerful shuttle xpc or a modified HP Slimline PC, both are good..but their power supplies are specially made for them. I cant seem to find a "P9" power DC-DC power supply that works with the hp slimline or the shuttle xpc, Can i hard wire it somehow using a normal ATX DC-DC power supply?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Probably the easiest way: Get an ATX to AT adapter, but yes you can hard wire it the same way.
    Elsewhere
    PSSST!
    Read the FAQs, man.
    There's likely a DC-DC PSU that will work well with either solution you are considering.
    How about the Wiki?
    Jan 2008
    what is "p9" power?
    locate the voltage output, and amperage ratings of the adapter, and then find the closest dc-dc option that puts out at least that much power..
    Apr 2009
    Quote Originally Posted by DarquePervert View Post
    PSSST!
    Read the FAQs, man.
    i did...i did hesitate on making a new thread about this...
    The P9 is stamp on the power connector coming from the power supply
    Mar 2004
    Florence Yall, BFKY
    Sorry, P9 is a 9 pin connector also know as an AT connector from pre-ATX days.
    Jan 2008
    thier are loads of adaptors to take a atx to p8 and p9 connectors
    http://www.pccables.com/00326.htm
    http://www.censuspc.com/ATX-to-AT-Ad...T-pr-4257.html
    Jan 2008
    whoops, my bad--i saw hp slimline, and started thinking of 19v power adapters...
  1. Replies: 0
    Last Post: 07-30-2009, 08:45 PM
  2. Replies: 5
    Last Post: 08-21-2007, 01:20 PM
  3. Power Supply
    By MrGee in forum Newbie
    Last Post: 06-21-2006, 05:44 PM
  4. Casetronic C137 120watt power supply
    By Change in forum Power Supplies
    Last Post: 11-13-2005, 09:15 PM
  5. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
