Results 1 to 5 of 5
Thread: need a simple regulator circuit
    Aug 2002
    longview washington
    i need something that will give me 6v dc at 2000ma <i forget what that converts to in real amps> used to know it from my days in r/c racing
    ps its for a digi cam to run it off either a small gel cel or a 7.2 volt r/c battery pack
    oh yeah radio shack parts would be great so i can make it asap
    WINNER!!!!
    run-on sentance comp 2002!!
    Constant Bitrate henkbliek's Avatar
    Dec 2002
    Netherlands
    If the voltage of the cel stays above ~7V, then you could use a LM1084 linear regulator. This one keeps working down to an input/output difference of about 0.9V at 2Amps.
    An alternative solution - if the input voltage and output current are fairly stable - is to use two series diodes, which gives depending on the type a voltage drop between 1 and 2V. But you only want this if the 6V is not too critical.
    white bream
    working on a trilogy: CARGO - UNIGO - MERGO
    CARGO = the Car Computer
    Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
    Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
    Aug 2002
    longview washington
    well since the camera is made to run off 4 aa batterys at 1.5 volts a piece for combined 6volts at 2000ma i am assuming thats its not too picky about stable voltage as long as its not over 6 volts
    what else would i need for the reg circuit ? or just the reg it self?
    WINNER!!!!
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    Re: need a simple regulator circuit
    Did the cam come with an AC-DC adaptor?
    If so, you might not need extra circuitry.
    Most digital gear comes with a built-in regulator and an unregulated dc adaptor, its output fluctuates with the load requirements.
    Aug 2002
    longview washington
    has the spot for the ac-dc adapter being as its a dam hp cam there is just enough there to get it to work and nothing else <they even want you to pay for the extra drivers for xp >
    anyways i think the ac adapter just taps into the internal battery circut and get regulated from there just a guess since the adapter supplies the same voltage as the 4 aa's that it uses
    so my plan of action is take one of my olde r/c stick battery packs cut them down from 6 or 7 cell to a 5 cell pack at 1.2 volts per cell gives me 6 volts and each cell can supply around 1300 ma
    a configuration like that gives me about a 20 min run time with high amperage dual motors in my trucks so it dhould give me a reallly long time for the camera
    all theory and speculation
    WINNER!!!!
