Results 1 to 6 of 6
Thread: Need 20 pin plus 4 pin PSU
    Jul 2009
    B.C., Canada
    My mobo requires a 20 pin molex connector and a 4 pin 12V molex connector. I was looking at getting the 120W Opus PSU but I can't tell if it comes with the additional 4 pin connector or not. Pictures look like yes, manual looks like no. Is it possible to build one if it doesn't? I have the connectors and pins at work.
    I was also wondering what gauge wire I should send to the PSU. I know this question has been asked a million times but I just want to make sure. The FAQ says I could get away with 14 guage, is this true? I have max 10' to go and this is my system:
    POWER CONSUMPTION
    ITEM.............................................. ......AMPS (A).......VOLTS (V)............POWER (W)
    AMD Athlon 64 1640 2.7GHz............................................ ..................................45
    Sirius SC-C1 with Mitch's adapter....................1.00.................12 ........................12
    BU-353 GPS Receiver....................................0.5... ................5.........................2.5
    Rocketfish Bluetooth USB Receiver..................0.5....................5 ........................2.5
    Lilliput 889GL-80NP/C/T................................................. .................................<9
    Panasonic Slimline DVD player............................................ ..............................5
    HDD............................................... .................................................. ...........10
    TOTAL............................................. .................................................. .........86
    PROGRESS:
    Hardware: 100%
    Software: 99% - Always upgrading and improving.
    Installation: 100%
    WORKLOG:
    2005 F-150
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    I would say the Opus 120 with 12 AWG wire at least, probably 10, is you can. Which 4-pin molex do you need? The one for the processor or the 24-pin ATX connector?
    This 4-pin plug(for the processor):
    Or this one (24 pin ATX)?:
    After a 2 year break, I'm back! There are so many new and familiar faces here!
    New vehicle, new ideas!
    Chryssi - The Changeling CarPC Project
    Elsewhere
    Quote Originally Posted by Tical84 View Post
    You can build or purchase a cable that taps a HDD power connector to supply the additional 12v to the 4-pin plug.
    I recommend 12awg at a bare minimum, even for a lower-power system such as yours.
    Don't forget the fuse!
    How about the Wiki?
    Jul 2009
    B.C., Canada
    Quote Originally Posted by freeflashstuff View Post
    Looks like the first one.
    Thanks to both for the guage recommendation too.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
    May 2008
    The Opus 120 comes with that plug(or, at least, mine did... )
    Worst case senario, you have to buy a $5 Molex to 4-pin P4 connector
    Jul 2009
    B.C., Canada
    Thanks, that's all I wanted to know. Their manual is deceiving since the 360W one says it has it clear as day.
    I can build my own from parts from work for $0. I just wanted to make sure if I spliced it in somewhere it wouldn't cause problems with something else.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 05-24-2012, 11:59 PM
  2. DSATX power question, un-needed wire on 20 pin?
    By greatwhite in forum Power Supplies
    Last Post: 10-21-2007, 01:21 PM
  3. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 09:15 AM
  4. 2 x 20 lcd pin numbering issue
    By cookspyder in forum LCD/Display
    Last Post: 07-08-2005, 09:11 AM
  5. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
