Results 1 to 10 of 11
Thread: simple 12v,5v,-5v,-12v power supply
    May 2003
    if i have an input of + and - 12v and ground, whats the simplest way to get +12v, +5v, -5v and -12v? with a regulator.
    edit: this is for a PC supply, so i needs to be 2A?
    Constant Bitrate GRUNT's Avatar
    Sep 2002
    Scotland
    Have a look at the Power Supplies section.
    Or search for DC-DC.
    Your looking for 12v DC-DC power supply.
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    I'd say that a sproggy psu would be the easiest way. Get a semi-kit from mastero and the rest of the parts from renco and maxim, more resellers too.
    May 2003
    ok, ill do a search.
    i want to build one so i want a circuit diagrma, not a kit
    for an old PC, a 486 for example, how much current for the +12v and +5v supplies do i need?
    if i have a 1A regulator, can it regulate higher currents if i keep the chip cool? with a huge heat sink and fan(s).
    how do i get 3.3v? and do i need it?
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    The amount of current all depends on the components. Old hdd's can draw an amp on the 12v line but a laptop hdd may draw max of 1/2 amp on only the 5v line. An old 486 won't need 3.3v but may take 5a on the 5v line. You can't run a regulator over its spec, most have overload and thermal shutdowns inside them.
    Variable Bitrate spud42's Avatar
    Oct 1999
    brisbane,qld,australia
    but you can use a power transistor as a current bypass and use the voltage regulator as a reference to it. ie using a 2n3055 and a 7812 you can get a 3 a 12v psu......... circuits should be on any site with basic electronics....
    Volvo V40 Phase 2 2002. T4 turbo upgrade.... currently no mp3 or carputer..... researching options
    May 2003
    any links? i have some 2n3055's.
    May 2003
    can i use this website? voltage regulator
    and is the MJE340 the same as the MJE34?
    if not, which of the following can i use instead of a MJE34?
    BD132
    BD140
    BD712
    MJ2955
    TIP32A
    TIP32C
    TIP36C
    TIP42A
    TIP127
    TIP147
    TIP2955
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    This took me about 2 minutes to find with Altavista:
    http://www.repairfaq.org/sam/samschem.htm#schslp2
    Apr 2000
    Bedfordshire, UK
    Here are more:
    http://www.mitedu.freeserve.co.uk/Ci...wer/boosti.htm
    http://www.chantronics.com.au/Data/V...regulators.htm
    This one is for a regulator with feedback (and adds headroom requirement due to the additional Vbe drop).
    http://dbserv.maxim-ic.com/appnotes....ote_number/295
