Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: DSATX overheat?
  1. #11
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Do you have enough juice (heavy gauge cable, no loose connection on the ground, etc.) going on to it? Re-check your connection points, see if there's not a short somewhere (eg. an open fan connector).
    I had a hacked ATX psu that couldn't provide enough amps to it as windows was loading. It could work okay on the bios page, but as soon windows was loading (HD spinning, USB etc.), it would happened similarly as you describe (IIRC), eventually ATX PSU output voltage would fall from 11.9v to 11.4v. or so I thought and it would shut down suddenly. That's all I can think of right now.
  2. #12
    Jan 2010
    i am trying to use the serial brainstem to monitor the voltage and temperature. But when i connect the brainstem to the dsatx, the auto turn on/shutdown doesnt work when i switch on/off ignition. Is it normal?
    there are many things to play around for the dsatx
  1. M4-ATX or DSATX
    By ibm_jennifer in forum Power Supplies
    Last Post: 04-22-2009, 11:36 AM
  2. DSATX w/brainstem Problem
    By TeamRSX in forum Power Supplies
    Last Post: 04-03-2008, 08:01 AM
  3. Problem with new DSATX
    By jbradshw in forum Power Supplies
    Last Post: 03-31-2008, 06:59 AM
  4. DSATX Showing Under/Over temp at ~75F
    By cherrybomb in forum Power Supplies
    Last Post: 09-13-2007, 03:43 PM
  5. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
