Results 1 to 10 of 12
Thread: DSATX overheat?
    Jan 2010
    DSATX overheat?
    I have been running my carputer for weeks, and my carputer sometimes shutdown suddenly and could not be powered up again for a few minutes. Will that because of overheat of DSATX?
    Just wondering if the DSATX sends a pulse to motherboard to shutdown the computer before cutting the power coz of the overheat? For those occasions, my computer just shutdown without any hints in advance.
    What will be the other possible causes for the such shutdown?
    Million thanks...
    Jan 2008
    What components are you powering?
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jan 2010
    It is a computer with PlatinumD 805 DC, it is only a standard PC with GPS, I don't believe power is an issue. Any view on this?
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    If it's overheating, you should see the led in it blinking 4 times. Mine overheated mounted in the trunk, when outside temp was over 100F.
    Do you see the main shutdown timer (1 blink) and then two blinks when the power off is sent and windows just shuts down or there's no warning blinks, it just cuts power and windows does not even know what happened?
    Jan 2010
    this happens randomly and the carputer has already been mounted in the boot, so i couldnt see the light.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    yeah probably overheat. mine does it too. i widh i had bought the brainstem so i could raise that Power-cut temperature a bit
    Dec 2007
    Danville, CA
    Right after it shuts down, the lights should still blinking untill acc is cut. Maybe you could then go to the boot and unscrew everything and see if it blinks?
    When left parked under the sun, does the computer starts? If it does, it's may not be overheating...
    If it's only when driving, it maybe be some motherboard connector not seated right, and then the vibration moves the plug/component and that crashes the MB.
    Apr 2006
    Greece
    Quote Originally Posted by RipplingHurst View Post
    actually that is not entirely true.. when it cuts power due to overheating, it does it violently..boom..no shut down.. And when left in the sun parked it might not allow you to even turn on..it happened to me once
    Dec 2007
    Danville, CA
    Quote Originally Posted by Nomader View Post
    I don't remember exactly how it happened and you may be right on this part, but I DO remember I could see it blinking 4x every time it wouldn't start.
    That happened to me a lot. I then switched to a wood enclosure (a drawer in the trunk), thought about air flow and the problem was gone.
    Jan 2010
    just checked...after my pc shutdown, the dsatx does not blink.....not light. After a few minutes, it starts working again....any clues?
  1. M4-ATX or DSATX
    By ibm_jennifer in forum Power Supplies
    Last Post: 04-22-2009, 10:36 AM
  2. DSATX w/brainstem Problem
    By TeamRSX in forum Power Supplies
    Last Post: 04-03-2008, 07:01 AM
  3. Problem with new DSATX
    By jbradshw in forum Power Supplies
    Last Post: 03-31-2008, 05:59 AM
  4. DSATX Showing Under/Over temp at ~75F
    By cherrybomb in forum Power Supplies
    Last Post: 09-13-2007, 02:43 PM
  5. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 08:47 PM
