Results 1 to 3 of 3
Thread: DSATX wont power up under load
    May 2006
    Exclamation DSATX wont power up under load
    Hey everyone, I want to first thank you all for the great information here. My CarPC adventure started in 2004, and I've been using a DSATX in my setup since 2006 with no problems. This morning however, on my drive to work, it suddenly cut out. I've fooled around with it, and here's what I've observed:
    - With everything connected normally, when I turn the car on, the LED on the DSATX does not light at all, and the standby-power indicator light on my motherboard pulses about once per second.
    - With the motherboard disconnected, the DSATX LED comes on solid, but if I then try to connect the motherboard, the DSATX LED cuts out entirely, and the motherboard light pulses as above.
    - Once, I was able to connect the motherboard after the DSATX LED was solid, and both LEDs went solid - but, when I tried to start the motherboard, it all went out - motherboard LED went to pulsing, DSATX LED off.
    - I have tested the motherboard with a standard ATX power supply, it it runs fine - the issue is somewhere in the DSATX.
    - I have +13.5 VDC on the VIN.
    - I only used the quick setup when I first got my DSATX, and I have never used a brainstem.
    - I disconnected the VIN for about a half hour to make sure it was fully reset, but it didn't make a difference.
    With my limited knowledge of electrical engineering, I suspect it may be a blown capacitor since the failures seem to be triggered by load - but I honestly have no idea. I didn't get the blown capacitor smell, and I don't see any physical defects. Any ideas here, or do I need to do an RMA?
    Apr 2009
    Newark, New Jersey, United States
    i am having the VERY same issue as above with two DSATX PSU's :-(
    i wish someone would have responded. although this thread is old, it would help others . ugh
    Apr 2001
    Portland OR
    Quote Originally Posted by trinybwoy View Post
    PM me if you are still having issues and I'll send you a firmware update..
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  1. DSATX w/brainstem Problem
    By TeamRSX in forum Power Supplies
    Last Post: 04-03-2008, 08:01 AM
  2. Problem with new DSATX
    By jbradshw in forum Power Supplies
    Last Post: 03-31-2008, 06:59 AM
  3. DSATX power question, un-needed wire on 20 pin?
    By greatwhite in forum Power Supplies
    Last Post: 10-21-2007, 01:21 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
