Results 1 to 10 of 12
Thread: Power Cut Out
    Newbie bakin113's Avatar
    Sep 2008
    Murrieta, California, United States
    Power Cut Out
    Hello,
    After I installed my carPc it worked great for about a week. Then the weather started to warm up and I noticed my 100 w inverter would stop supplying power to my laptop, which would make it think the it was running on battery and shut down. I originally thought the inverter was overheating because it was in a confined center console. So I unplugged it for a couple days. I soldiered the power cables to a wire of the same gauge, about a foot-long, and it worked great, for about 20 minutes.
    Now I'm thinking it's pulling more than the alternator is supplying the car. Before I had the monitor, I had run the laptop(dell d400) and inverter for a couple months, using an iTouch to change the songs. So I'm thinking that the monitor (7" lilliput eby 701) and the laptop are now pulling too much. The power brick says it pulls about 65w and the monitor says it pulls about 10w.
    How would I got about testing this? Hook up a multimeter to the battery? What would I be looking out for? I want to thoroughly test this before I do something like replace the alternator. Also, If the laptop were booting up on battery, and turning back off a few times over a couple days, would that make the charger pull more current to charge the laptop battery? I am going to pull the laptop in and charge it off the wall socket and put it back in with a charged battery to see if I get a change...
    Any answers would be greatly appreciated.
    Hardware: Two Diamond Audio D3 10" subs, 7" Lilliput eby701, 2.7Ghz AMD 45w Sempron, Gigabyte mobo, 512MB nVidia 9800, 1GB RAM, 500 GB, M4ATX
    Software: OpenMobile
    My First Build
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    You are definatly overloading that 100 watt inverter, don't forget that 100 watts is peak i am sure not constant, either buy a bigger inverter or get dc laptop brick or a real power supply for carputing hope this helps SNO
    Sep 2008
    defiantly helps, thanks SNO; I plan on a real PSU when I build a real carPc.. for now I'm running the broke student approach with a laptop. I'll check to the dc-dc bricks.
    My First Build
    Nov 2009
    Keswick,On Canada
    I'm not sure where you live but here http://www.canadacomputers.com/produ...item_id=016109 is the best deal i have found on a dc laptop converter, and they ship fast and reliable. this is what i use for my aopen bb10 unit more than enough power and run your monitor either from 12v car power or through your lighter socket or 100 watt inverter SNO
    Sep 2008
    Well, I don't see dc-dc being my fix any more. Being an apple wannabe, dell keeps most of their products from working with aftermarket products. I've been reading that dell chargers have a chip in the brick that opens the laptop to take power. The dell branded dcdc bricks were about $80. Instead I ordered a continuous 220w inverter for about $20; I'll see how it acts when it's delivered and report back for any one else having a similar issue...
    My First Build
    Raw Wave
    Nov 2009
    Did a salesperson claim the brick-chip?
    I wonder if it's a 3rd pin of if they use ac signaling...?
    I doubt the brick chip story, but I have seen companies that stupid.
    Sep 2008
    Quote Originally Posted by OldSpark View Post
    I don't remember.. it was a while back when I was ac-dc brick for dell laptop, on dell's website I thought... but the plug into the laptop has an outer connector, an inner connector, and a male plug in the middle; it could be for ac signaling..
    My First Build
    Jan 2008
    no, sadly, this is true-- there is a 'signal injector'(i want to say that it is the 3rd pin on the charger, but not sure) on some of the dell chargers that tell the laptop to accept the charge from the charger, and without that signal, it will not charge. there are at least 2-3 threads on this in the laptop section i remember coming across-- where people actually tried to use a standard charger, but it wouldn't work because of this signal injector junk...
    Raw Wave
    Nov 2009
    That's a good enough reason to avoid Dell.
    I bet they do not sell those here (in Aus).
    Sep 2008
    I recommend avoiding dell... custom built ftw.. but, i never argue with free... the laptop came from my grandma and was useless. I wiped the hd and took it apart, put it back together and now it runs in my car
    I got my new inverter in and no problems at all.. just under $20 delivered, its a 400w, 220w continuous from walmart online.
    My First Build
  1. Power problem I would like some acvice on please.
    By sebberry in forum Power Supplies
    Last Post: 05-26-2010, 02:19 AM
  2. Replies: 0
    Last Post: 07-30-2009, 08:45 PM
  3. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
