Results 1 to 4 of 4
Thread: GP83 160W Intelligent DC-DC PSU Won't power up my amp
    Jun 2010
    I am having issues with this power supply turning on my amp. Everything to the amp is good but for some reason it won't kick on. I have tried starting up with the amp hooked to both pins (not at the same time) with no success.
    Please help me out. Thanks
    EDIT: Also, does anyone know the pin settings for the start up-shut down timings? I read the instructions 5 times and couldn't find it anywhere.
    Jan 2008
    if the amp powers on using a normal acc line, then you might need to use a transistor-- like what is used on the m2 power supplies(you can find out more in the m2 area).
    Jun 2010
    I ended up just tying it in on the ACC line. Works fine now.
    May 2010
    I use the yellow and black line to power my touchscreen, I haven't tried the amp turn-on but You could just hook the yellow wire from the 4 pin connecter to the remote turn on to the amp and it should work the same.
    also google "gp83 psu info" and there is a PDF for the timers
    I'm having trouble with my gp83 not turning on/off the cpu when the ACC wire is is given power, it turns on/off then I short the 2 wires from the j8 to the cpu switch legs together but I cant get the dang PSU to control it.
  1. FAQ: How do I power my DC-DC PSU on my workbench?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 12-14-2011, 07:55 PM
  2. GP83 160W PSU Holding Power Buttons
    By capcadetjc in forum General Hardware Discussion
    Last Post: 06-11-2010, 01:47 AM
  3. Review: M4-ATX 250 Watt Intelligent Power Supply
    By Bugbyte in forum The Review Palace
    Last Post: 12-21-2009, 09:52 AM
  4. Hooking both ac and dc power to psu at same time.
    By smean in forum Power Supplies
    Last Post: 07-22-2008, 11:53 PM
  5. M2-ATX 160W Intelligent DC-DC PSU
    By canibusfan in forum General Hardware Discussion
    Last Post: 09-05-2006, 11:56 PM
