Results 1 to 6 of 6
Thread: Computer won't boot wough ith brainstem hooked up to DSATX
    Feb 2004
    I did my first power up today of my computer using a dsatx with brainstem. The first time I applied power, the computer went through tshree brief rounds of starting and immediately stopping. I never hot plugged the brainstem. After some troubleshooting, I found that if I removed the brainstem the computer booted. I tried switching the brainstem to a different COM header port and ran into the same problem. I then left the brainstem connected to the DSATX, but disconnected the serial connection. The computer booted fine. I then went back to attaching to a COM header, with the same result. Lastly, I tried hooking up the DSATX via a Serial to USB adapter and the computer did nothing.
    I've ran into one other post where a user had similar issues, but as far as I know, Jeff never answered him.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    most everyone with a dsatx had this same issue. The brainstem is defective from the factory sadly.
    Live mp3Car Facebook Chat
    Feb 2004
    Quote Originally Posted by Sonicxtacy02 View Post
    So are you saying that the brainstem doesn't work, or that mine is just defective, and I need to return it?
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Mears View Post
    the brainstem only works if its connected to a computer that the dsatx isnt powering. Its not just yours its all of them, but you should be able to return it i suppose.
    Jan 2010
    I have this issue before, but it can easily be fixed. The braintem unstable issue (e.g. counldnt boot sometimes, no diagnostic data output) is due to the serial brainstem gets the 5v power from the dsatx J2 port.
    The resolution is to connect only the TX and RX wires of the brainstem to the dsatx J2, meanwhile connects the 5v and ground wires to the harddisk power cable (I.e. the 4 pins power cable connecting the psu to the harddisk or cdrom), such that the brainstem will not get the power directly from the dsatx J2 port.
    I have been using this setup for a month and it is very stable now.
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    ^^ I can't wait to test this. I was thinking about this weekend, but with World Cup, Soccer, Nascar, and F1 this weekend...maybe not...
  1. DSATX Brainstem
    By Rick99TAWS6 in forum Power Supplies
    Last Post: 05-03-2008, 04:48 PM
  2. DSATX Brainstem Guidelines
    By zootjeff in forum Power Supplies
    Last Post: 01-03-2008, 06:31 PM
  3. computer hooked up to windows?
    By eric in forum General Hardware Discussion
    Last Post: 07-26-2003, 12:25 AM
  4. Computer wont boot
    By phil.45 in forum Power Supplies
    Last Post: 07-18-2002, 08:58 AM
  5. Can this LCD screen be hooked up to a computer??
    By brandondere in forum General Hardware Discussion
    Last Post: 03-10-2001, 05:01 PM
