Results 1 to 7 of 7
Thread: DC-DC Question....
    May 2003
    New Mexico
    DC-DC Question....
    I see alot of you on here are using DC-DC PSU. Whats the advantage of these compared to inverters? Also whats involved in putting them in a vehicle? Will it run off my battery? I also want to know EVERYTHING I need to put a pc in my truck using a DC-DC psu, and where I will be able to get all the supplies. Thanks in advance.
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    the big reason people use them is when they crank the car to start it their computer will stay running. Some inverters give off line noise so thats another problem to deal with.. plus its another thing you gotta try to hide.
    dc-dc is small and silent.
    '98 Explorer Sport
    80% done
    Sep 2001
    I've got the Keypower DC-DC and it reboots when I crank.
    Dec 2002
    Netherlands
    I have a 12vdc to 220vac inverter and the comp does not reboot when i start the car.
    The battery is down in about 30min but thats something else.
    More info here----> http://www.gijsje.net
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    Thats a good point. A DC-DC PSU is a lot more efficient than an inverter... meaning your system is gonna drain less juice from your battery.
    May 2003
    New Mexico
    so a dc-dc psu will run off my battery without any mods? How many wires are involed? Is it just a ground, a +12v, and a ACC wire?
    Aug 2002
    No. It's more complicated . Do a search .
