Results 1 to 10 of 16
Thread: Power wiring.
    Jul 2010
    Power wiring.
    Originally posted in mewbie section but i think its better off here to get a reply
    At the moment i have a 400W amp and a 1600W amp powering component speakers and a sub. The sub has a power cap and is all in the boot. I want to put my computer in the boot aswell and was wondering the best place to take power from the battery. Could I use the same power cable as the sub? And if so should I take it off before or after the capacitor? I was planning on using something like this power supply:
    http://linitx.com/viewproduct.php?prodid=11664
    And was wondering wheter that would be sufficent or would I need more equipment?
    Basic diagram:
    Thanks in advance
    Alarr
    Elsewhere
    If you tap the power line from the sub, use a distribution block.
    Otherwise run a dedicated, fused line to the battery.
    How about the Wiki?
    Jul 2010
    Awesome im thinking before the cap as the volatage between cap and sub will be haywire whereas the batt to cap should be pretty stable?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by Alarr View Post
    Caps smooth out ripples from the battery and charging system. Power is either cleaner after the cap, or dirty on both sides (if your system is inadequite)
    RevFE
    My Shop
    Jul 2010
    Yeah but would it be dirtier on the sub side because I have a 1600W sub blasting out?
    Jul 2010
    I would instal the distribution block, and put the cap between it and the sub amp.
    Given the low price of power caps I doubt it really matters. But Ideally you would isolate the sub amp from the rest of the system. The computer PS can take care of voltage regulation for the car pc.
    The wire to the trunk should be big. Sorry, the "boot".
    Raw Wave
    Nov 2009
    The cap smooths out the power on both sides. Only the cable resistance (ie distance) from the cap effects that. (Please people - basic electronic circuit theory - all points on the same "wire" are at the same voltage.)
    But since the cap is there due to amp thumping (and probably a great sales pitch**), run a dedicated line from the battery, otherwise your PC will be subject to the same line dips as the sub.
    (** replacing the cap with a small AGM battery will probably have superior effect.)
    Jul 2010
    The cap was only bought cause when i had my music on and was driving my lights went off and engine started to cut out... :P
    Kk Probs best to give it its own line for the price of the cable.
    Raw Wave
    Nov 2009
    Exactly!
    I'm just saying that a small AGM battery would have been more effective. And probably cheaper.
    (Although a 1.2AH battery will do, most use a 7AH because they are under $40, and you can usually use it to jump-start your car if needed - try doing that with a cap.)
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    If your system is draining your storage capacity that bad then you have a bigger issue. A spare battery or cap does not generate anything. Only the alternator provides what you really need: more power.
    Your first order of business should be an HO alternator, (you can get one aftermarket if the OEM does not offer one), then do what what is known in the car audio world as "the big three". Constant low voltage in your vehicle due to overload can cause lots of weird problems.
    You can google "The big three" for many results or just go here:
    http://www.the12volt.com/installbay/...TID~73496~PN~1
  1. Power
    By ssteger in forum VaultWiki
    Last Post: 10-14-2009, 03:59 PM
  2. Need Help Wiring Power To Touchscreen(Newbie)
    By BIGGKATT01 in forum LCD/Display
    Last Post: 09-16-2007, 08:20 PM
  3. Wiring power from Ignition Switch
    By briderx in forum Power Supplies
    Last Post: 09-15-2007, 06:33 AM
  4. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  5. just about wiring to power...
    By Deep in forum Newbie
    Last Post: 05-23-2005, 12:51 AM
