Results 1 to 10 of 17
Thread: "simulating" a battery
    Jun 2007
    St. Louis
    Se here's an interesting situation.... I have a QStarx 818x...love the reception, very reliable signal...however the battery crapped out (apparently it cooked itself while inside the dash panel under the windshield). Without the battery, it will not stay on. It will simply turn on and when the juice runs out, it shuts off until the battery charges enough for it to turn on again.
    So is there a way to 'simulate' that there is a battery? I noticed there are 3 terminals on the battery, and the battery is 3.7v (I think, maybe 3.6v). It takes the 5v input from the USB and uses that to charge the battery. How could I take that 5v and make the GPS receiver work without the battery in?
    I tried just jumpering the 5v to the battery terminals but it didn't work. Also tried a variable resistor in line to adjust the voltage to 3.7 but it seemed to fluctuate a lot...my guess is that 3rd terminal is some sort of 'feedback' and the charging circuit is trying to compensate to the missing feedback.
    Ideas? I can post pics of the circuit board if needed.
    Thanks,
    Raw Wave
    Nov 2009
    A capacitor may do the trick. Hopefully charging it from zero won't be an (over-current) issue.
    The 3rd wire is probably a voltage feedback to indicated battery charge state which has to be simulated (maybe a resistive divider) but you have to find its relation ship for simulation.
    I'd expect if you found that, a charger alone should work (excluding "peak" current surges that overtax the charger).
    Jun 2007
    St. Louis
    Would opening up the battery help any on that 3rd terminal?
    I hadn't thought of the Cap...I may rig something up with a cap + variable resistor for the current and see if anything comes of that.
    I'm itchin' to hardwire the thing so there's no battery needed, if I were to replace this battery, it will have been the 3rd one in less than 2 years.
    Raw Wave
    Nov 2009
    Opening the battery - maybe... but you might just find a chip.
    Can you find the specs on the battery - maybe its a "typical" Li-Ion (3.6V is a common phone battery) - it sounds wrong for a LiPo type?
    Or find what voltage that 3rd terminal provides for a full battery, then merely the USB into the device, and a resistive divider (2 resistors or a trimpot) across the USB 5V to the 3rd terminal.
    (Warning - it's been a while since I looked at 3-terminal batteries....)
    Jun 2007
    St. Louis
    I'll dig that info up tomorrow and see what I can find. Thanks for the tips, I'll post back tomorrow with what I find out. I know it's a Li-Ion and not a Li-Po battery. My other GPS receiver may use a similar (if not the same) battery...haven't checked and haven't thought to until now. I'll charge it fully and take some readings from it.
    Mar 2006
    Colorado, but Canadian!
    removing the battery completely will mean the gps receiver will have to do a full lock every startup (probably 10minutes +)
    But anyways, if you have a friend with an oscilliscope or a friend that goes to university for electrical or computer engineering, I would have them probe the 3rd mystery port.
    It could be a digital IO pin, not a simple analogue output voltage.
    1.9in x 2.9in -- 47mm x 73mm
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Most likely on a single cell Li-Ion pack, the 3rd pin is a thermal sensor and often times is labeled TS. Check that's there's no voltage between (-) and TS. Read ohms, set it in the fridge for 10 mins and check again. It should slowly rise back to the original reading.
    I wouldn't connect it directly to 5V since it's looking for 3.7V and has a charge circuit. It would be better to use an adjustable linear regulator and diode (compensate for the diode voltage drop) and connect it to constant power.
    Mar 2006
    I've seen that before with the thermal sensor, but the last pack I took apart from a laptop had a 1 wire serial interface. The battey was spewing out serial data from that thrid pin. There was an initial start character that was the same every time, then about 3 or 4 bytes of data, then the line went dead for a second, and it started again...
    So different things can happen. I would definately suggest to the OP to try what you said and check if it is a simple thermal output. But nowadays, even some batteries require MCU communication...
    Mar 2004
    Florence Yall, BFKY
    Oh yes, a multi-cell Li-Po setup needs to do a lot of work. There's a thermal sensor on each cell or at least 1 shared between each 2 cells, plus a wire between each one to monitor individual cell voltage. If just 1 cell is overcharged or drains too much it can create a hazzard.
    Jun 2007
    St. Louis
    ok - took it all apart and took some readings.
    There are two pads on the board. One is labeled Vbus, the other vBat. When plugging the receiver into USB WITHOUT the battery I get the readings labeled in the picture below.
    Now, when the battery is plugged and charging, the T terminal reads 0v, vBus =5v, vBat = 3.67v
    Would a simple resistor + cap setup bridging the - and T? This is where I'm lost
    possibly a relay triggered by a cap that shorts the T to ground?
    :EDIT: I forgot to mention...reading the resistance from T to ground I get 67k ohms. Would simply jumpering T to ground via 67k resistor be a possibility?
  1. Measuring Initial Car Battery Voltage Help Needed
    By pblakeney in forum General Hardware Discussion
    Last Post: 11-11-2010, 09:37 PM
  2. How to hook up extra battery?
    By dbarrett480 in forum Car Audio
    Last Post: 04-10-2010, 02:50 AM
  3. should I get a capacitor?
    By dragger5258 in forum Car Audio
    Last Post: 02-01-2010, 06:35 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. time to a dead car battery?
    By chuckctv in forum Newbie
    Last Post: 08-20-2004, 11:08 PM
