Results 1 to 2 of 2
Thread: how to power up my usb drive 5volts on 6 m cable ?
    Apr 2009
    At home
    Well guys i need to know which is the best option to power a DVD RW usb powered on my car. I mean i have an Aopen External DVD RW Drive powered only by usb. And works on 5volts.
    I have to power these on a 6 m distance between the drive and the pc....The problem is that i dont get this working well cause there is a light but the dvd doesnt open and so i guess it isnt well powered.
    So i was wondering if i can power this with any kind of usb powered hub or get a 5 volt power supply to work on cars..i mean a 12 v to 5 v converter/or something like that.
    Or maybe a pci usb card which has 4 ports......???
    It works on 5 volts and 2 A....I had found a 5 v 2A already but has to be changed to work....i mean...need to get the correct plug...
    What options do i have ? May i use a usb hub powered directly from my car...i have chance to get the power directly from my battery or near that, like the cigar lighter....if needed...
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    you can use something like this to get 12v automotive to 5v 1amp using 1 of these
    and use with usb cable with dual ends (1end in to this power unit and 1 end into your extention cable to your computer) or open it up and solder on your connector for your dvd drive 5v power in hope this helps SNO
  1. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 12:26 PM
  2. Replies: 115
    Last Post: 03-05-2011, 03:54 AM
  3. USB DVD/RW issues
    By kamikaze2112 in forum General Hardware Discussion
    Last Post: 08-04-2006, 10:43 AM
  4. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  5. wierd, slim dvd -> USB adaper MUST use ps/2 port for power...
    By mattress in forum General Hardware Discussion
    Last Post: 04-05-2005, 06:15 PM
