Results 1 to 6 of 6
Thread: psu run in parallel?
    Jul 2010
    i was searching for a way to converter a standard 120vac psu into a 12vdc input but it seems like more of a challenge than i thought but in my searching i came across a suggestion of possibly running 2 or more psu's in parallel to get the wattage out put i need.
    Now is this possible or am i limited to using a start up/ shutdown controller with a power inverter.
    Either way ill make it work i just want to know the best route to take.
    Mar 2006
    Colorado, but Canadian!
    Why are you not using a dc-dc solution. They are so cheap nowadays, it is really a no brainer.
    1.9in x 2.9in -- 47mm x 73mm
    Raw Wave
    Nov 2009
    No to parallel supplies.
    But with 250W supplies available, what's your problem?
    Jan 2008
    he is trying to figure out how to run a xbox360 without a inverter
    Powering Xbox360
    the adapter cable he was looking at in that thread requires a power supply capable of 16.5 amps on the 12v line, and 1 amp on the 5v line..
    Raw Wave
    Nov 2009
    Ah - big consumers....
    Why not convert its SMPS to DC as was done elsewhere (another (old?) mp3car thread?)?
    (Though I'd probably rather stay standard and use an inverter.)
    5V/1A is no problem, but 12V/16A (regulated) - that's a fat choke on a 60A MOSFETed $5 power chip.
    Mar 2006
    I just get an inverter and be done with it. If you want to avoid some of the issues, get a true sine wave inverter
  1. Replies: 2
    Last Post: 10-25-2008, 02:00 PM
  2. FAQ: Will <insert PSU model> Power Supply work with my system?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 10-10-2006, 01:38 PM
  3. Replies: 0
    Last Post: 02-16-2006, 02:48 PM
  4. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
  5. Inverter and PSU success
    By magnetik in forum Power Supplies
    Last Post: 09-22-2001, 08:19 AM
