Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: acid bass?
    Constant Bitrate vull's Avatar
    Oct 2007
    acid bass?
    lol...
    how the hell could this have happened? too much bass? charging fumes blocked?
    both?
    i had this blue rug between the terminal and chassis... it might have blocked the venting hole, because that was pointing upwards? (acid came out from the hose connector hole?
    the side looked freshly wet, but it dried to some white bits after i had charged the battery...
    brushed a bit and then vacuumed:
    the paper was still wet too:
    the car stood still for couple of weeks, before the PC drained all the power :P
    after installing the PC, i got the sound working with it and listened to some intense bass for many times...
    it seems that the sides of the battery are so soft that if i push it inwards, the venting hole will whistle as there's air going through it...
    even if the rug was blocking the venting hole a bit - would it be so intense pressure for the acid come out of the battery? :s
    imo it was ok before installing the PC an enjoying the sound (and there's like 5mm of the acid still left on top of the plates and is working fine atm)
    Nov 2006
    Rubidoux, CA
    The battery was probably over-filled, at a low state of charge, and then heavily/over charged, causing it to get hot, and overflow out the vent. FYI, this is why battery boxes are made out of plastic...
    2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
    Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
    Oct 2007
    how could it have been overfilled? it creates water?
    it has been working fine and noone has added any liquids into it...
    Nov 2006
    Rubidoux, CA
    so you've checked the levels?
    Jan 2008
    Dartmouth, MA
    Why wasn't the venting tube hooked up to drain outside of the car?
    What brand is that battery?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Oct 2007
    didnt think that i would need such a 'hook'
    battery is RayLit 72Ah, 680A (somekind of Diesel Booster)
    i've had to charge it couple of times before due to some lights left on in the car and the levels have never been high imo. how much is too much anyway? i think i would have spotted it
    Constant Bitrate Sleepyz0mby's Avatar
    Feb 2010
    PanamaCityBeach/NewOrleans
    did you park the car at an extreme angle? this is why motorcycle batteries vent to the right.
    if it wasn't over charged or over filled and didn't turn over thats the only thing i can think of.
    Oct 2007
    crap... i did drive at a quite steep angle, many times, because that's what i had to do to get to a house
    weird that it hasnt done this before though - ive been to the same house many times before and imo i've reversed out of the garden before too(maybe not so many times as this time, buit still)... maybe the high weather temperatures played a role in there? :s
    although the venting hole was pointing upwards... i dont think it could have come out from there?
    i think i'll have to do the bass test brb
    Oct 2007
    ah, dunno... bass seems to move only the stuff that is situated over the bass element (+some random chassis parts)
    battery walls didnt seem to move at all. dunno about the liquid inside. atleast it didnt come out on a leveled gorund...
    Feb 2010
    man oh man, peeled the paint right off... i bet theres a battery box in there next time
    it may have been charged too fast?
    i'm surprised oldspark or soundman has chimed in yet.
  1. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 10:52 AM
  2. Bass channel not loud enough
    By spoonraker in forum Car Audio
    Last Post: 01-14-2007, 09:18 PM
  3. bass boost
    By tundra2000 in forum Road Runner
    Last Post: 07-17-2006, 12:10 PM
  4. How do you control Bass??
    By PhatMo in forum Car Audio
    Last Post: 06-16-2006, 10:09 PM
  5. Controlling fade, balance + bass idea...
    By Scouse Monkey in forum General Hardware Discussion
    Last Post: 12-10-2004, 06:22 PM
