1. If you live in the Netherlands, it is 230 volts AC from the wall. There is no 12 volts AC. The brick you are plugging in contains a transformer that converts the
power to 12vdc.
2. Use a multimeter to measure the power at the end of the wire that plugs into the speakers. That is almost sure to be 12vdc.
3. If so, cut the wire and connect the + to the proper battery terminal and the ground to the proper battery terminal. I NEVER go by the wire color or striping. Always measure t with a digital multimeter to test it, first.
4. There are many tutorials on YouTube that explain how to use a multimeter. It is your best friend!
