Results 1 to 10 of 19
Thread: Time relay for CAR-PC...
    Aug 2010
    Hello everyone,
    I am a newbie at the forum and have one simple question.
    I am planing to instal CAR-PC.
    I will be using miniITX board which has single voltage supply from 5 to 25 V DC.
    I can control to turn ON and turn OFF the board, but would like to have time relay, which would completly remove the power supply to my board after 5 minutes.
    This is just for making sure that board doesn't hang up at shutdown sequence and drain my battery.
    Consumption of whole system (motherboard, LVDS LCD - powered from motherboard, some USB peripheral, SSD and some other stuff) is around 30 Watts.
    So relay needs to be for 12 V DC and current of 5 Amps.
    Thank you for help.
    Jul 2009
    Most car PSUs labelled "intelligent" will do this for you.
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Hey
    I'm building one today.
    Parts bought from radio shack for ~$10.
    I'll post some pics and schematic when done.
    Aug 2010
    Quote Originally Posted by billmee View Post
    Hey
    I don't need it anymore
    I bought myself DCDC-USB which is perfect product and consumes less than 1mA in sleep mode which is not a problem for my battery.
    Also you can configure times manualy and this is just perfect for my application.
    Thank you anyway.
    Raw Wave
    Nov 2009
    billmee - post it anyhow, maybe in a new thread. (For others.)
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    I am mainly looking for a pulse relay. A relay that will pulse when the trigger is ON, and pulse again when the trigger is OFF. Is there any such device?
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
    Raw Wave
    Nov 2009
    Try the12volt.com if nobody here can assist - though I suggest a search before posting.
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    I don't know if this meet requirements but I have something in the works for myself, but could be used by others.
    What I'm having build, is a board that has a picaxe chip on, that can control the power up sequence and power down also. When the acc. line goes active, it will activate one relay after 7 secs, and another a bit after. The times can be corrected, if needed, to any number. When the acc. line goes off, the board holds the relays for ie. 20 sec's and then cuts. Again the 20 secs can be anything.
    The board also have a low voltage detect so that battery is not drained.
    The board will tie to permanent 12 V and the acc. line and will have 2 outputs, one for amps (very low amp relay) and one rated at about 10 amps for other stuff including the pc.
    The only thing missing is a way to tell the pc to shut down or hybernate. Serial switch is one way to do it.
    Just set bios to power up on power loss and it should boot when power is applied. Some mini-itx cases have this auto boot feature (including mine - http://mini-itx.com/store/?c=54 )
    Tell me what you think, I will have one board made for myself with everything mounted and then there will be 4 spare boards left not mounted.
    Blessed are the "cracked" for it is they who let in the light.
    Jan 2008
    Quote Originally Posted by checksum View Post
    check here:
    http://www.crutchfield.com/S-dVygJEw...ay-Module.html
    Feb 2006
    Columbia/MD
    Quote Originally Posted by soundman98 View Post
    I am not sure if this will work. I am trying to achieve the same thing that the M4-ATX does with the power switch on a computer. Send a pulse when ACC is detected (power on), and send another pulse when ACC if gone (power off).
    I am trying to power another device that has a push button ON/OFF switch, and I don't want to buy a M4-ATX just for that purpose.
    thx
