Results 1 to 10 of 16
Thread: Truck Driver Need's a little help.
    Oct 2010
    I am a truck driver and my setup is a bit heavy duty..
    My alt. is a 170amp and my main battery bank is 4 group 31 in parallel.
    connected to it is a 3000 watt Inverter that powers all my hotel loads, fridge,micro and computer.
    My problem my inverter does not survive crank.(flips out actually)
    This is really really irritating me so..
    What i want to do is add an extra battery(mebby 2) to my bank with a cut out ckt to disconnect the extra battery when the engine cranks.MY inverter would be hooked up to the
    battery's that are disconnected.
    I am having a hard time finding a good solenoid for the purpose.
    I think I want a 500amp normally closed non latching type.
    any idea's where I can find such a beast ?
    I think I may have a solution for myself, Bep Marine makes this little gadget..
    http://www.bepmarine.com/home-mainme...ive-relay-vsr-
    I am going to pick one of these up and see if it will work for me.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I think by the time you spend the time & money doing what you suggested, you would be further ahead adding a proper carputer power supply that is designed to handle the tasks of startup, shutdown, cranking etc. Also the computer would end up getting cleaner power than it would from the invertor and you will have less computer issues.
    Oct 2010
    all right I will consider not using an inverter to power my pc.
    my current computer is an Intel quad core 2.2ghz cpu
    video card is a radeon 5870 <recent> upgrade
    8 gig ram
    5 500gig 2.5 and 3 1TB 2.5 inch hard disk's.
    I will eventually replace all my 500 gig drives with 1tb drives and the total number of drives will go up to 10 drives.
    I have no Idea what my total power usage is but my 1000watt ps seems to handle it ok.
    I have looked around for a good DC to DC power supply for my computer I haven't been able to find anything that comes even close to a 1000 watt ps.
    if you can point me in the right direction to find such a beast I would be grateful.
    Jan 2008
    most of us don't use that much power in-car..
    in fact, most don't even use anything more then on-board graphics..
    for 360watt+ pc's, a inverter is going to be your best option(the opus 360 is the highest dc-dc psu i know of)
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    We use these relays at work: http://www.mouser.com/ProductDetail/Stancor/124-910/?qs=sGAEpiMZZMtSzCF3XBhmW1unbvAnCJgIIQso0WptNCs%3d
    They are quite nice, and make good cutout relays for just what you are looking for.
    RevFE
    My Shop
    Raw Wave
    Nov 2009
    On the original theme (a relay) - forget voltage sensing (too complex, to expensive, too many issues...).
    It'd be better using a normally closed relay that is pulled open during cranking - ie, the starter solenoid (wire) energises the relay.
    And it would only need to be the one battery else 2 batteries (I'm assuming cranking draws more than the inverter.
    The "opposite" is a relay that closes during charging to connect battery arrays. A charge lamp circuit can usually switch on a relay (when the charge lamp is off - ie, charging) - in this case probably a small relay that switches on the bigger 400A-500A relay.
    Oct 2010
    Start quote from Old Spark
    It'd be better using a normally closed relay that is pulled open during cranking - ie, the starter solenoid (wire) energies the relay.
    end quote
    That's exactly what I am looking for is an 200-300 amp normally closed Relay, and so far have found zip.. I can find latching or N.O relay's but normally closed it's been like finding hen's teeth.
    I decided to go with this
    http://www.ase-supply.com/Sure_Power...p-1314-200.htm
    it was only 120 bux with shipping, I will Install and report on how well this works out for me.
    Raw Wave
    Nov 2009
    I've done similar for 250A for about $25 - and FAR, more reliably! I think 400A was ~$35. Add a switch and diodes ($2-$5) for manual bypasses etc.
    The NC solution is to use a standard changeover relay to drive the heavy relay/contactor.
    IE - the first SPDT (changeover) relay is energised by the starter circuit. That breaks the NC contacts (#30 & #87a) that energise the main relay.
    The problem with high-current NC is that there needs to be adequate force holding the contacts together. NC is fine for lower currents (in non-vibrational applications), but a reliable connection is under force - ie, held in contact with an energised coil.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by JackTheKnife View Post
    Wow, that web site is like a candy store to me
    Raw Wave
    Nov 2009
    LOL - all I see is silly voltage relays, ancient Pertronix, and Bosch alternators....
    But there is good stuff similar to malcom2073's relay (eg, Cole Hersee 24143; 12V Continuous Duty 200A $35.14).
    At the12volt.com I saw some >200A relays for about $20 to $25....
    Though for a full 3kW inverter I'd want at least a 300A device....
  1. Theme for my truck!
    By HiJackZX1 in forum Off Topic
    Last Post: 12-31-2008, 01:55 PM
  2. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  3. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 11:52 AM
  4. FedoraCore4 - Wireless issues?
    By frederic in forum Linux
    Last Post: 02-01-2006, 09:09 PM
