Results 1 to 5 of 5
Thread: solution to cranking power probs?
    May 2003
    UK
    what about putting one of these farad capacitors in the +line between batt and your computer? anyone tried this? does it have enough stored power to keep PC running?
    James
    May 2003
    UK
    ok lets work this through
    1 farad
    Q=CV
    1x12 = 12 columbs of charge stored
    1 amp = 1 coloumb per second
    start engine 3 secs max
    this means the capacitor can output 4amps for the 3 secs it takes to start a car...
    55W low power supply for VIA EPIA m/b draws 4.5amps at full load, running at less than full prob be about 4 amps
    i dont have any farad capacitors handy, but someone that does might wanna have a go !!
    ps. tell me if any of my maths is dodgy lol
    James
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    supplying the amperage is not a problem. Voltage is what the problem is. inverters shut down when the voltage drop below 10.5 volts. Even if you put a cap in, the voltage will still drop below 10.5 volts during crank. You need to isolate the cap from the battery so that when you crank the engine, the voltage on the cap doesnt drop at all. You have to put a high amperage diode between the battery and the cap. Diode has a voltage drop of .7 volts. A weak battery at 12.3 volts will actually feed 11.6 volts to the inverter after the power passes through the diode. This is what a tank circuit is. this topic has been discussed and done many many times. And yes it does work if installed correctly.
    NEW complete and updated My project with 100+ pics on 7-4-03
    If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
    May 2003
    UK
    :S, still should be simple with a small circuit to switch across when voltage drops below say 11v...
    James
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Yup, should be simple.... we have several egghead electronics types on this board.... go ahead and build one that is not much money, small and reliable.....
    TruckinMP3
    Read the FAQ!
