i would check for any bad capacitors (i.e. bulging heads, discoloration, or they just get really hot). barring that, you may add more capacitors on the output line to try and get rid of any voltage ripple. if that doesnt work, you might add a small inductor in series of the output, then on the output side of the inductor put a capacitor, this helps get rid of high frequency noise, other than that, it probably just isnt worth it to put much more work into it.
LinkBack URL
About LinkBacks
