Results 11 to 20 of 23
Thread: Constant crashing... Help
  1. #11
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    What kind of relay would i use for this application, http://www.mpegbox.com/microsdc/usdc20d_AuxOC.pdf
    Would this from the mp3car store work: http://store.mp3car.com/10pack_of_25..._p/com-085.htm
  2. #12
    Jan 2008
    any relay can work-- i would prefer a automotive type relay, but you could also use a smaller 5 volt relay off the 5v line of the power supply..
  3. #13
    Sep 2006
    New York, New York
    I put in a 12Vdc relay i got from radioshack. The f1/f2 jumper on the DSatx never give an on signal so I'm still using the 12v rail of the power supply to trigger the relay. That works fine. I think the cpu is overheating causing the system to cut off hard. I'll take off the case top and see if its any better.
  4. #14
    Sep 2006
    New York, New York
    so i cut an aperture into the case and put a grill in its place on top of the cpu fan... still no better. Still cutting off. Let's see what happens when i get the point of loads for the screen.
  5. #15
    Newbie SGAsgard's Avatar
    Sep 2009
    Terrebonne, QC, Canada
    why don't you go to the basic, try to power only the comp with the DSATX and see if the computer shut off, if it is try installing a program to monitor the cpu temperature to see if that what causing the shut off.
    English is not my first language so if I say something weird just say it to me and i try to be clearer :) :)
  6. #16
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    +1
    Pull the computer from the car. Set it up in the house, use a PSU that connects to AC power, connect nothing else except keyboard and mouse/monitor. See if it behaves normally.
    Add the usb stuff in the same manner as in the car, check for same behavior. If you don't get that behavior, try to figure out what is different in the car than what is working in the house.
    Add stuff back one item at a time to try and replicate the behavior. Wire it the same as in the car.
    Want to:
  7. #17
    Sep 2006
    New York, New York
    Everything is pulled out. Hooked to an extra car battery. I have only the hard drive and board powered via the dsatx and it crashes still. I noticed that the dsatx stays on the computer fails and just turns right off. I touched the northbridge... Cool. I touch the CPU heatsink... Cool. I remove the 3.5" hard drive and put in a full size desktop hard drive I had laying around. Boots right up. What's going on here? Anybody seen this before.
    I can hook up the 3.5 to my pc and read it fine. I tried formatting and reinstalling win on it. It installed fine but refuses to fully boot up. Even in the desktop. It doesn't crash but stalls. I'm going to get a point of load for the monitor but I'd like to know what went wrong in the first place, and why reading is now possible but booting isn't from the 3.5.
  8. #18
    Sep 2009
    did you mean 2,5" (laptop drive) or 3,5" full desktop hard drive?
  9. #19
    Jan 2008
    have you tried running a hdd test yet?(most brands have one on their site) it sounds like the drive is starting to fail..
  10. #20
    Sep 2006
    New York, New York
    when i took the pc apart I found that the spu fan was not totally on. It was the factory fan, with cheap plastic clips. That might be the issue. I'll run a hard drive test too and get an after market fan with under-board mount.
  1. Winamp crashing
    By jbradshw in forum Road Runner
    Last Post: 03-09-2010, 08:53 AM
  2. Constant fix? Constant 5v supply?
    By TheGuv in forum GPS
    Last Post: 07-14-2009, 10:55 AM
  3. Constant power to BU-353
    By Kimota in forum GPS
    Last Post: 09-12-2007, 04:51 PM
  4. FYI: found random crashing cause/solution
    By dominic in forum General Hardware Discussion
    Last Post: 07-15-2005, 08:39 AM
  5. MM keeps crashing?
    By miztahsparklez in forum Map Monkey
    Last Post: 03-09-2005, 02:40 AM
