Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Constant crashing... Help
  1. #21
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    So i got a low profile cpu fan which moves a lot more air and has a bracket to secure to,.. no plastic clips.
    The stock fan had come loose enough to not be making full contact. That was causing the shut down issues. I decided to reinstall everything fresh. But now i'm having an issue with my dvi lilliput.
    Its not getting a signal from the computer. When I startup I see the splash screen then I see the glowing windows icon, then... nothing. Before then nothing, then screen was all staticy looking. I left it as is cause i could still see the desktop. But now after a couple of restarts, its dead. In the car I use the vga hookup but i don't have an extra lilliput to vga cord. So i'm using the dvi input. Anyone have this happen to them before?
  2. #22
    Sep 2006
    New York, New York
    So I found an extra lilliput vga cord, and its working fine. I don't care if the dvi doesn't work,.. I'm never going to use it anyway.
    Funny thin is when I use the regular atx power supply, the computer will not stay off. Whether i put it in hibernate, or sleep, or hit the power button, or turn it off via the start menu... it turns off then immediately restarts. But with the dsatx it stays off.
    I got to say I've built so many computers and i've never had as many obstacles as with one car computer. Hardware is one major issue and the software is major issue.
    You guys know of any reason why the computer won't stay off with an in house atx power supply.
  3. #23
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    what are the bios settings for power off feature sounds like its set to restart on power failure just a thought SNO
  1. Winamp crashing
    By jbradshw in forum Road Runner
    Last Post: 03-09-2010, 08:53 AM
  2. Constant fix? Constant 5v supply?
    By TheGuv in forum GPS
    Last Post: 07-14-2009, 10:55 AM
  3. Constant power to BU-353
    By Kimota in forum GPS
    Last Post: 09-12-2007, 04:51 PM
  4. FYI: found random crashing cause/solution
    By dominic in forum General Hardware Discussion
    Last Post: 07-15-2005, 08:39 AM
  5. MM keeps crashing?
    By miztahsparklez in forum Map Monkey
    Last Post: 03-09-2005, 02:40 AM
