Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Constant crashing... Help
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    Here's my setup:
    - Memory - G.SKILL 2GB 240-Pin DDR2 800
    - Hard drive - Western Digital Scorpio Blue WD800BEVT 80GB 5400 RPM 2.5" SATA 3.0Gb/s
    - MB - Intel BOXDG45FC LGA 775 Intel G45 Mini ITX Intel Motherboard
    - Processor - Intel Pentium Dual-Core E6500 Wolfdale 2.93GHz Dual-Core Processor (65watt)
    - Case - Morex 5677 Mini-ITX Case w/ 2.5" HDD Mount with PSU
    - Power - DSATX
    - Screen - lilliput 7"
    - GPS - BU-353 Weather-proof GPS Receiver
    - Radio - Boomzbox
    - Wifi - Wireless 802.11b/g/n USB Wi-Fi Dongle
    - Bluetooth - Nano Hi-Speed USB 2.0 Bluetooth Network adapter by Interlink
    The DsAtx is powering the computer and screen off a fused 5v rail and the amp signal off a 5v rail, I haven't gotten to doing the relay of of JP1/F1 yet. But even without the amp hooked up this problem still exists. I'm using Centrafuse 3.0. Centrafuse doesn't load my gps on com8. I have to start the gps from the desktop. Then it will see the gps... sometimes... Bluetooth via blusoleil fails all the time. And then only way to get it back is to restart the comp. After Bluetooth fails or anything else fails if i go into the settings to try something the comp just crashes. It doesn't go into shut sequence it just crashes. Like pulling the plug on a home computer from the wall. Also, Centrafuse takes control of everything so i can't use the bluetooth function or boomzbox outside of centrafuse.
    What would cause the power to just cut off? Also if i forgo Centrafuse cause of these software issues... what would you guys suggest? But really this power cut off is the major issue.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Power issue for sure, have you tried with atx 120v power supply or nothing on the 5v rail. I power my accessories via separate power supplies and gps/bluetooth/skype phone/active-sync/tpms/touchscreen/radio/sound card/wifi/video capture/web cam all work everytime.
    Jan 2008
    could you post a quick diagram? i am partially confused on how everything is powered, or working off 5v power..
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Screen takes 12 volts, doesn't it? Are you sure it isn't just the SCREEN that is going blank? Maybe when you load all that stuff up, the voltage is dropping too low on the 5v rail and the screen goes blank.
    It sounds like you have the lilli hooked up to 5V....
    Want to:
    Jan 2008
    to add-- i have never tried 5v on a amp, but some amps might actually require 12v on the acc line..
    Sep 2006
    New York, New York
    Sorry, the amp and screen are getting 12v via the dsatx. I'll get some point of loads and see what happens. I'll run the screen off the power filter/sig. lighter for now and see if that helps. I'll get the powered usd hub soon.
    Sep 2006
    New York, New York
    Quote Originally Posted by soundman98 View Post
    could you post a quick diagram?.
    Jan 2008
    did you have issues with a turn-on pop? why not connect the amps remote line directly to the cars acc line?
    Sep 2006
    New York, New York
    the amp gets a 12v signal from a molex 4 pin from the dsatx on the 12v rail.
    Jan 2008
    the amp could be trying to draw too much from the dsatx.
  1. Winamp crashing
    By jbradshw in forum Road Runner
    Last Post: 03-09-2010, 08:53 AM
  2. Constant fix? Constant 5v supply?
    By TheGuv in forum GPS
    Last Post: 07-14-2009, 10:55 AM
  3. Constant power to BU-353
    By Kimota in forum GPS
    Last Post: 09-12-2007, 04:51 PM
  4. FYI: found random crashing cause/solution
    By dominic in forum General Hardware Discussion
    Last Post: 07-15-2005, 08:39 AM
  5. MM keeps crashing?
    By miztahsparklez in forum Map Monkey
    Last Post: 03-09-2005, 02:40 AM
