Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: Optional Power Switch (M2-ATX)
  1. #11
    Low Bitrate scottholmes's Avatar
    Oct 2006
    I just find ebay easier, and im incredibly lazy! Was only 2.25 delivered, and to be honest its easier than trying to find a decent parts store online in the UK that isnt Halfords, and i hate them!
    I wasnt sure if i could link to eBay or not so didnt want to post just in case!
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    Scott
  2. #12
    Variable Bitrate Wayne613's Avatar
    Apr 2009
    Delaware
    Yep, that should be fine.
    2008 Ford Mustang GT/CS CARPC(99%)
    Software: Ride/Road-Runner, Digital FX skin 5.x, iGuidance 2011, GPSgate on Win7 64bit
  3. #13
    Oct 2006
    Excellent, just the power wire, DAB Radio and then the hardest thing to find will be the monitor/fabrication and im sorted! I can start looking for the car then, lol.
    Thanks for your help
    Scott
  4. #14
    Feb 2010
    Kentucky
    Small FYI with the LED on the M2...
    I believe (and I will double check when I get home) that the M2 keeps both pins for the LED high and then lights the LED by grounding one with the output of the PIC.
    You can always just ignore the LED on a switch like the one I linked, and it is easy to double check your connections with a multimeter before you install it to make sure you understand what is happening at each contact. I have mine wired with a pretty high current limiting resistor (10k I think) in order to match the brightness of the LED to the rest of the red lights in the car. However, mine is just wired with the anode (+ terminal) of the LED connected to the side of the switch that is not permanently wired to +12V. When the switch is on the LED is on, and when it's off the LED is off... Simple enough.
    edit:
    I just realized that first comment might be confusing... the M2 can flash an LED. I am planning on eventually connecting the LED output of the M2 to my ACC switch LED so I can see it in the front of the car, so it is useful information if you ever wanted to do something similar...
  5. #15
    Apr 2009
    Delaware
    I get why you'd think you'd want this, however, and again this might just be me personally, but..
    Why not simply run a parallel line off the shutdown leads going to the MB so you can manually turn it on/off in that manner with a momentary SPST button, the same as you'd have on your desktop/laptop computer?
    I can't speak for this PSU, but there have been instances where I switched too fast between ACC and off and the PSU's controller didn't sense things correctly, so it didn't turn on; things like this are very infrequent, but they do happen. So [to me] at least you'd probably want this at some point anyhow, even if it's not visible.
  6. #16
    Oct 2006
    Quote Originally Posted by Wayne613 View Post
    With my limited auto elec prowess, id have no idea how to do that
    Scott
  7. #17
    Apr 2009
    Delaware
    Not really like Oldspark's in-depth detailed electronic theory really. Keeping in mind your aversion to soldering; you would just essentially cut the motherboard shutdown leads at some length, and attach a second line off of each lead, twist the two together and use a crimp line connector to re-attach it to the PSU single lead for each of the shutdown/start leads. So you still have the PSU's ability to control shutdown/start-up, but also leads going to a button for manual control if you need it.
    The PSU still has the power of veto with the microcontroller should it sense an undervolt or the ACC line isn't powered at all. But if it fails for some reason, or you just don't want it to fully power back up, you can just push the button or hold it on for 5 seconds to force it off, the same as you would for a laptop/desktop.
    It actually kinda surprises me that none I've seen that are sold for the express purpose of powering a mobile computer (boat, car or whatever) don't already have something like a dual-tap for this built-on. *shrug*
  8. #18
    Oct 2006
    The motherboard shut down lead is the 2pin connector wire (at both ends) that runs from the M2 to the power PIN on the motherboard, i think its black and red?
  9. #19
    Apr 2009
    Delaware
    Quote Originally Posted by scottholmes View Post
    Actually, speak of the devil, I take that back. After your question I viewed the manual for the M2 from mini-box, it has J9 which is in parallel with J8, which is for the shutdown leads. So this one actually has it all set to go for you, no splicing required. Of course you need to provide the other 2pin connector line yourself, but..
    Yep, the 2 pin small plastic tap that goes to the motherboard, usually red and black for the wire colors.
    It has an external LED tap as well should you wish to use it, J5.
    Here's the manual from the mp3car store, as I think you bought yours from here, right? I assume the 2 are essentially the same, but just in case the firmware revisions are different or they changed some hardware..Basic jumper layout is the same as far as I can tell. *shrug* Don't really care much for this "HV" version..doesn't have the ability from the power settings jumpers to operate past 30 seconds after ACC is cut without disabling the hard-cutoff. Kinda cheese that it doesn't have 10 and/or 15min settings like the other.
  10. #20
    Raw Wave
    Nov 2009
    Not really like Oldspark's in-depth detailed electronic theory really...
    Aw... shucks!
    Funny that that was mentioned... I read this thread but didn't bother reviewing the modes etc.
    But I had a feeling my usual old tricks would work.... (eg, a relay energised by push-button ACC or IGN or alternator charge that could latch/stay on until some other signal or button or loss of the turn-on signal - but you guys know those simple relay plus switch or diode circuits...).
    BTW - yet again I agree with Wayne's perceptive comments on how things should or could work, and what is lacking....
    (That's without any in-depth analysis, and (LOL!) after resolving hypotheticals related to melted cables thru bad connections.)
  1. FAQ: How do I power my DC-DC PSU on my workbench?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 12-14-2011, 06:55 PM
  2. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 04:56 PM
  3. Power Supply/OPUS Kill Switch
    By SpaceMonkey in forum Power Supplies
    Last Post: 08-11-2006, 10:58 AM
  4. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 11:24 AM
  5. Opus atx power (on off) like this?
    By Mad Ad in forum Hardware Development
    Last Post: 05-08-2005, 07:11 PM
