Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: here's a tough one... 6v car
  1. #11
    Oct 2001
    Ontario, Canada
    you can't regulate up, you have to use an inverting circuit. You can build one but it'll only handle a few amps. anything major and you're looking at an expensive setup to boost 6V->12V. As mentioned, you could just drop in a 12V alternator and be done.
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
  2. #12
    Constant Bitrate Suprapc's Avatar
    Apr 2003
    Scott, La
    I would get the inverter from jcwhitney + a charger controller (can be had from one of those charge one car from another without opening the hood things<don't know the name> +a 12 volt battery. Wire the inverter to the 6-volt battery (which gets charged) to the charge controller (so the 12 volt doesn't overcharge) to the 12-volt, which will be charged by the previous. Yes you can do this it does work I've done it for a while in a 66 vw bus.
    2002 Golf TDI With Phatbox . Blue 87 Supra Needs to go, Grey 89 Targa with stock Radio.
