Results 1 to 4 of 4
Thread: PSU vs Heat
    Constant Bitrate 4ofakind's Avatar
    Jul 2009
    PSU vs Heat
    I have an Opus 360w PSU. It will not fit in my current CarPC chassis (See why HERE). So I am building a seperate chassis for the Opus using a project box. My question is; since the project box will completely enclose the PSU, will I need any holes for heat mangement? The only thing in the project box will be the Opus PSU, so no other heat generators. Will it get hot enough by itself to shut down?
    Mal
    Vehicle: [100%] 1995 C 1500 ECLB
    Gear: [90%]
    Build: [80%] PC & Chassis, Worklog
    Apr 2009
    Newark, New Jersey, United States
    based on my experince with my dsatx i would give a resounding yes!
    i was in the same situation as urself, i put my psu in a project box , drilled some ventalation holes and (prepare youself for the dumb part...) mounted it upside down in trunk of my car.
    on hot summer days the pc would shut off for no apprent reason! . then i reaslized that it was due the psu overheating in the project box.
    i then installed a cpu fan to suck the air out of the box.
    the air it sucked out was preety warm to the touch.
    Variable Bitrate Wayne613's Avatar
    Apr 2009
    Delaware
    Quote Originally Posted by 4ofakind View Post
    *snip*
    Yep. Enclosed even with vent holes I still think you'll have issues. I have the same exact one, I don't have heat issues with the PSU itself, but only because it's open-air mounted. Definitely going to want to give it some at least minor active venting if enclosed.
    2008 Ford Mustang GT/CS CARPC(99%)
    Software: Ride/Road-Runner, Digital FX skin 5.x, iGuidance 2011, GPSgate on Win7 64bit
    Jul 2009
    Thanks guys. Will get some fans to push/pull air through the box.
    Mal
    Gear: [90%]
  1. Should distribution block fuses be used?!?
    By lexdiamond20 in forum Newbie
    Last Post: 11-04-2012, 11:11 PM
  2. Replies: 5
    Last Post: 06-20-2007, 02:21 PM
  3. Replies: 0
    Last Post: 02-16-2006, 02:48 PM
  4. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  5. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 01:08 AM
