Thanks boelle, I googled around and found out exactly that - shorting the green pin to ground should do the trick. I'm most likely not going to power the amp from M3 - I don't think it could handle the load. I'll try to wire the Power mobo wire to the power switch on the nettop - it should do the trick (hopefully).
