Results 1 to 10 of 11
Thread: DC DC converter extending connection cable possible?
    Apr 2009
    At home
    Hi!
    I wanna know if can modify my DC DC converter (12 V to 5V) i plan to put on my car.
    I wanna know if its possible to extend the cable that goes from the DC DC to the device i wanna connect to. I mean, this cable needs more 30 cm at least to get on the device i plan to install but what i need to know is if there is any problem with the voltage/current that will have, since i am making changes to the original one.
    The DC DC goes for 2 Ampere current and i really need the 2A cause i will connect a DVD drive and its really 2A.
    THANKS!
    Jan 2008
    why not extend the converter to the location of the dvd drive? that way, your extending it before the voltage regulator, so the dvd drive can get the full power without a problem..
    Apr 2009
    At home
    Quote Originally Posted by soundman98 View Post
    I dont have room for the converter....any thoughts?
    Jan 2008
    what model converter are you using?
    Apr 2009
    At home
    HQ converter its PSP suitable too.
    Its a 12 V to 5 V dc dc with car lighter socket
    Jan 2008
    the only reason i ask is because member Oldspark pointed a site out a while back that makes a very small converter that might work for you to put near the dvd drive:
    http://www.lightobject.com/DC-to-DC-...V-2A-P540.aspx
    at only 50mm X 40mm footprint, it is really small, and should do 2A (though it might need a heat sink)
    anyways..
    technically, 30-40cm should be ok for extending the wire, though i am a little concerned because you need the maximum amperage that the psu puts out-- so any little drop will directly affect the device..
    Raw Wave
    Nov 2009
    Disconnect the converter's sense point and extend that to the the load.
    Apr 2009
    At home
    Quote Originally Posted by OldSpark View Post
    What is sense point ??
    Raw Wave
    Nov 2009
    Switched-mode converters sample the output voltage to increase or decrease (regulate) their output.
    It is usually a resistive (voltage) divide at the output.
    EG - the converter circuit's (IC or chip's) may have an internal reference voltage of 1.2V. For a 5V output, make 5V look like 1.2V - ie, a 1.2:5 divider - eg, a 3.8k & 1.2k resistor (see Wiki - voltage or resistive divider).
    Rather than change the resistors to boost the voltage, it's better to extend them to the output. IE - disconnect the "top" resistor (to its +5V output) and use a wire from its "top" to the load +5V. A thin wire should be fine (it's only uA or mA), though you may have to be careful with interference....
    (It the same in principle as linear regulators, alternators etc. This "extended" sense line is equivalent to the Sense terminal of a car's regulator/alternator.)
    Reality depends on the chip (converter) being used. It may have sufficient noise filtering etc.
    Jan 2008
    ^^ great idea!! in laymans terms, you are making the power supply account for the longer power wire, instead of you trying to work around it..
  1. AC - 12v DC Converter For Testing
    By GeoLogic in forum Power Supplies
    Last Post: 01-11-2009, 09:13 PM
  2. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  3. Extending LCD cable
    By CoyoteBoy in forum LCD/Display
    Last Post: 05-27-2004, 01:32 AM
  4. Laptop LCD Idea ... extending the interface cable
    By RaginRover in forum LCD/Display
    Last Post: 07-09-2003, 01:03 AM
  5. extending the cable length of keyboard?
    By dizzzyduck in forum General Hardware Discussion
    Last Post: 07-25-2000, 04:53 PM
