Results 1 to 2 of 2
Thread: Power!
    Aug 2010
    Power!
    Hello,
    I have looked at the chart that is avalible but just want to make sure.
    I need to know what wire I'm going to need to power the following.
    I currently have a 4 guage which goes to a distribution box splitting to two 8 gauge cables powering my:
    Vibe A0 Slick Amp:
    # 2-channel Amplifier (Bridgeable mono)
    # RMS output @ 4ohm: 2 x 75W
    # RMS output @ 2ohm: 2 x 100W
    # RMS 1 channel bridged @ 4-ohm: 1 x 200W
    # Max power: 400W
    and
    FLI 15" 1200w Sub:
    RMS power – 400 watts
    Peak power – 1200 watts
    Minimum Input – 200 watts RMS
    I have purchased an M4-ATX PSU for my carputer. If I was to purchase a new distribution block to split the 4 gauge cable into three 8 gauge cables would this be enough power for each device?
    It's a renault clio so the 4 gauge probably runs about 3/4 meters?
    Any help will be apprechiated,
    Thanks,
    Jack.
    Jan 2008
    the easiest way is to always add up the fuses--on almost all devices, the fuse rating is the max expected load of the device..
    so the m4 has a 25a fuse, and the amp has 2 15 amp fuses, so a assumed total draw of 55amps..
    and my nice lil' chart:
    which shows that 4 ga is fine for that amount of load.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  1. Choosing a DC-DC Power Supply
    By ssteger in forum VaultWiki
    Last Post: 10-14-2009, 03:57 PM
  2. Power
    Last Post: 10-14-2009, 02:59 PM
  3. Hardware Review: M3-ATX Power Suply
    By Bimmerstyle in forum The Review Palace
    Last Post: 03-05-2008, 05:57 PM
  4. Replies: 7
    Last Post: 06-15-2004, 09:29 PM
