Results 11 to 20 of 24
Thread: Can anyone identify this connector? DCDC-USB VAux question
  1. #11
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Looks like a typical 2mm JST connector.
    http://search.digikey.com/scripts/Dk...keywords=phr-2
  2. #12
    mp3Car Staff
    Jensen2000's Avatar
    Feb 2009
    Seattle, Washington, USA
    Blog Entries
    79
    I'm also checking with Min-Box on this. Hopefully I'll have better results with a response. I'll let you know what I find out.
    Have a product you would like to sell on the mp3Car Store? PM me for more information.
    Have a car computer question? Ask me by emailing the store.
  3. #13
    Jun 2007
    Boston MA
    Awesome! Thanks for your help everyone - it does look like it's a JST connector. I'll go order some and report back when I get them.
    I think DCDC-USB should ship with this connector since it's not a standard 2 pin polarized header connector. One can hope, right?
  4. #14
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    if you grab hold of the white surround with a pair of small pliers it will slide upwards on the pins. you can pull it right off this way. no need to break it off. you can then use a standard 2.54mm pitch 1x2 header connector. glue it down with hotmelt (hot glue gun) if you're worried about rigidity
  5. #15
    May 2008
    Bend, OR
    nivanov did the connector fit?
  6. #16
    Jun 2007
    Boston MA
    Nope, at least not the one I ordered. I had header connectors (metal things without the plastic around them) - I crimped some wires onto them, and wrapped the metal outisde with electrical tape. They sit on the contacts pretty tight and the way my power supply is facing (upwards), there's no stress for them to unplug so I left it at that. If you decide to put your power supply on the side, I suggest you take some putty and put it around the connectors to prevent them from falling out, if you don't find a proper JST connector.
  7. #17
    Dec 2007
    NY
    Did anyone find the name for this? What's the min guage wire should I use for this? Right now I'm looking at using a 26 guage to power the lilliput 669. Is that good enough?
  8. #18
    Jan 2008
    how far are you running the wire? i would feel better about running 18, or 16ga wire..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  9. #19
    Dec 2007
    NY
    Less than 1 ft then it will splice into the lilliput cig adapter which I believe is 5ft. I just decided to look at the adapter and it is 22ga. I just wish I could find this adapter so I could make a proper connection sinse the 26ga wire and header connection I have is now out of the question.
  10. #20
    Jan 2008
    normally 2 conductor wire like that is just called 'zipcord', or 'speaker wire'. usually hardware stores carry something in a similar gauge.
    HID retro--100%
  1. HFP for Linux Bluetooth Hands Free
    By samr7 in forum Linux
    Last Post: 04-25-2012, 05:45 AM
  2. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 12:26 PM
  3. dockingstation -> USB question...
    By porto in forum Input Devices
    Last Post: 08-22-2010, 03:43 PM
  4. Question on powering USB devices off of 5v line on molex connector
    By S4Per in forum General Hardware Discussion
    Last Post: 11-03-2006, 02:44 PM
  5. usb question?
    By cubanmoses in forum General Hardware Discussion
    Last Post: 07-25-2003, 12:27 AM
