Results 1 to 9 of 9
Thread: nslu2 + hubs what psu?
    Aug 2010
    I'm looking to put a Linksys NSLU2 and 2 powered usb hubs into my car, can anyone recommend a 5v output psu that would be up to the job?
    thanks
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    This one from mini-box should do it. http://www.mini-box.com/DCDC-USB If you need more than 10 amps, you're into some specialization.
    Want to:
    Aug 2010
    thanks for the reply, 10amps will be plenty, how many 5v outputs does this have? sorry give me a linux machine to build and i'll do it but i'm rubbish when it comes to power stuff ha.
    Jan 2008
    it has a single user-configurable power output.
    Aug 2010
    Can you recommend something that has 3 5v outputs that can handle up to 5A?
    Jan 2008
    5A per output? or 5A total?
    Jun 2008
    Perth, Western Australia
    If all of the parts are going to be turned on and off at the same time, you only need one output. Just split the output yourself into however many 5V feeds you need.
    You can do it either by tapping one main line with as many branches as you need (include fuses as required), or you can set yourself up a nifty little distribution block that you can add or remove lines from as your situation changes (Again, include fuses as required!).
    So while the DCDC has only one output, you can split that one output to as many devices as you want, as long as the total power draw is under 10A, which for an NSLU2 and a couple of hubs with devices attached, should be pretty easy
    Aug 2010
    Quote Originally Posted by soundman98 View Post
    5A total
    Quote Originally Posted by Chester View Post
    Ahh I see what your saying so would use single feed they split across an aux fuse box for example?
    Jan 2008
    Quote Originally Posted by stretch View Post
    that would be the best way to do it.
  1. 650W PSU blew up my dual XEON setup
    By Chris31 in forum Off Topic
    Last Post: 09-23-2006, 08:55 AM
  2. Remove Case DC-DC PSU?
    By Uther in forum Power Supplies
    Last Post: 08-27-2006, 11:33 AM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  4. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 12:04 PM
  5. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 01:08 AM
